svetotehnik
#1 Posted : Saturday, February 20, 2021 5:42:36 PM(UTC)
svetotehnik
Russian Federation
My goal is to write the volume value from XML and convert it from string to integer
but at this line interpreter returns error: "Input string was not in a correct format"
Code:
dim WhatISVolumeInt as integer = Convert.toInt32(WhatISVolumeComma)
replacing a period with a comma nor convert to a double does not help
Code:
dim xml as string = API.XML()
x.loadxml(xml)
dim WhatISVolume as string = (x.SelectSingleNode("//input[@title='Music']/@volume").Value)
dim WhatISVolumeComma as string = ""
If WhatISVolume.Contains(".") Then
    WhatISVolumeComma = WhatISVolume.Replace(".", ",")
End If
for i as integer = 0 to WhatISVolumeInt
             API.Function("SetVolume",Input:="Music",Value:=WhatISVolumeInt)
             WhatISVolumeInt = WhatISVolumeInt-1
sleep(8)
next
and yes, I know about SetVolumeFade function =)
#2 Posted : Saturday, February 20, 2021 6:02:03 PM(UTC)
In case this might help (not sure what you're trying to do)
The Volume level in vMix is linked to amplitude and scales with the following formula:
Volume = 0 to 100 (used for UI volume bars)
Amplitude = 0 to 1 (used for API Meter and Volume values)
Decibels = 0 dB to -infinity
Volume = (Amplitude ^ 0.25) * 100
Amplitude = (Volume / 100) ^ 4
Example
VolumeBar = 50
Amplitude = 0.0625
MeterF = 0.0625
VolumeXML = 6.25
P.S meter values in XML are in Amplitude 0-1, while volume values in XML are in Amplitude 0-100
dmwkr
#3 Posted : Saturday, February 20, 2021 6:35:44 PM(UTC)
dmwkr
Originally Posted by: svetotehnik Go to Quoted Post
Code:
dim WhatISVolumeInt as integer = Convert.toInt32(WhatISVolumeInt)
Line 13 of your code contains the variable WhatISVolumeInt twice. Doesn't seem right.
svetotehnik
#4 Posted : Saturday, February 20, 2021 6:39:14 PM(UTC)
svetotehnik
Russian Federation
Amplitude is not available from API, MeterF is current level value, not Volume
svetotehnik
#5 Posted : Saturday, February 20, 2021 6:43:43 PM(UTC)
svetotehnik
Russian Federation
Code:
typo, corrected
this way it does not works too
Code:
#6 Posted : Saturday, February 20, 2021 6:53:28 PM(UTC)
Not sure what you are getting at , seems you want the value before the period to return as a single integer ?
Code:
Dim IWant = Convert.ToInt32(WhatISVolume.Split("."c)(0))
or
Code:
Console.WriteLine(Math.Ceiling(Convert.ToDecimal(WhatISVolume )))
Console.WriteLine(Math.Floor(Convert.ToDecimal(WhatISVolume )))
Console.WriteLine(Math.Round(Convert.ToDecimal(WhatISVolume )))
svetotehnik on 2/20/2021(UTC)
svetotehnik
#7 Posted : Saturday, February 20, 2021 7:10:39 PM(UTC)
svetotehnik
Russian Federation
Code:
or
Yes, value before period was solution:
Code:
x.loadxml(xml)
Dim WhatISVolumeComma as string = WhatISVolume
   WhatISVolumeComma = WhatISVolume.Substring(0, WhatISVolume.IndexOf("."))
End If
sleep(8)
next
Thank you!
matkeane
#8 Posted : Saturday, February 20, 2021 9:37:03 PM(UTC)
matkeane
Was thanked: 21 time(s) in 21 post(s)
Does VBscript have support for locales? I've written code in the past which assumed decimal values would include a period, which of course failed the first time it encountered input from a different locale where commas are used as the decimal separator. Just curious how VBscript deals with that.
