Converting string from API.XML to integer
Joined: 11/6/2020(UTC) Posts: 21  Location: Saint-Petersburg Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
My goal is to write the volume value from XML and convert it from string to integer but at this line interpreter returns error: "Input string was not in a correct format" Code:dim WhatISVolumeInt as integer = Convert.toInt32(WhatISVolumeComma)
replacing a period with a comma nor convert to a double does not help Code:dim xml as string = API.XML()
x.loadxml(xml)
dim WhatISVolume as string = (x.SelectSingleNode("//input[@title='Music']/@volume").Value)
dim WhatISVolumeComma as string = ""
If WhatISVolume.Contains(".") Then
WhatISVolumeComma = WhatISVolume.Replace(".", ",")
End If
for i as integer = 0 to WhatISVolumeInt
API.Function("SetVolume",Input:="Music",Value:=WhatISVolumeInt)
WhatISVolumeInt = WhatISVolumeInt-1
sleep(8)
next
and yes, I know about SetVolumeFade function =)
In case this might help (not sure what you're trying to do) Quote:The Volume level in vMix is linked to amplitude and scales with the following formula:
Volume = 0 to 100 (used for UI volume bars) Amplitude = 0 to 1 (used for API Meter and Volume values) Decibels = 0 dB to -infinity
Volume = (Amplitude ^ 0.25) * 100 Amplitude = (Volume / 100) ^ 4
Example VolumeBar = 50 Amplitude = 0.0625 MeterF = 0.0625 VolumeXML = 6.25
Martin vMix
P.S meter values in XML are in Amplitude 0-1, while volume values in XML are in Amplitude 0-100
Thanks: 64 times Was thanked: 160 time(s) in 144 post(s)
Originally Posted by: svetotehnik  Code:
dim WhatISVolumeInt as integer = Convert.toInt32(WhatISVolumeInt)
Line 13 of your code contains the variable WhatISVolumeInt twice. Doesn't seem right.
Amplitude is not available from API, MeterF is current level value, not Volume
Line 13 of your code contains the variable WhatISVolumeInt twice. Doesn't seem right. typo, corrected this way it does not works too Code:dim WhatISVolumeInt as integer = Convert.toInt32(WhatISVolumeComma)
Joined: 12/27/2012(UTC) Posts: 5,541  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Not sure what you are getting at , seems you want the value before the period to return as a single integer ? Code:Dim IWant = Convert.ToInt32(WhatISVolume.Split("."c)(0))
or Code:Console.WriteLine(Math.Ceiling(Convert.ToDecimal(WhatISVolume )))
Console.WriteLine(Math.Floor(Convert.ToDecimal(WhatISVolume )))
Console.WriteLine(Math.Round(Convert.ToDecimal(WhatISVolume )))
Originally Posted by: doggy  Not sure what you are getting at , seems you want the value before the period to return as a single integer ? Code:Dim IWant = Convert.ToInt32(WhatISVolume.Split("."c)(0))
or Quote:Console.WriteLine(Math.Ceiling(Convert.ToDecimal(WhatISVolume ))) Console.WriteLine(Math.Floor(Convert.ToDecimal(WhatISVolume ))) Console.WriteLine(Math.Round(Convert.ToDecimal(WhatISVolume )))
Yes, value before period was solution: Code:dim xml as string = API.XML()
x.loadxml(xml)
Dim WhatISVolumeComma as string = WhatISVolume
WhatISVolumeComma = WhatISVolume.Substring(0, WhatISVolume.IndexOf("."))
End If
sleep(8)
next
Thank you!
Joined: 10/6/2020(UTC) Posts: 98  Was thanked: 21 time(s) in 21 post(s)
Does VBscript have support for locales? I've written code in the past which assumed decimal values would include a period, which of course failed the first time it encountered input from a different locale where commas are used as the decimal separator. Just curious how VBscript deals with that.
