brokensword
#1 Posted : Wednesday, February 17, 2021 9:01:10 PM(UTC)
brokensword
Hi I'm new to vMix. I have discovered this wonderful software and would like some information from those who use it.
I haven't tried the replays yet but before buying I wanted to know if my need can be solved.
I need to have two cameras under replay. The two cameras are connected via SDI to the main PC with vMix. Can I convert the two cameras to NDI to send them to another PC for replays? And can I use the NDI output of replays as input into vMix to go on air?
I hope I explained myself well, sorry for the English but I use google translate.
Thanks to everyone in advance.
xaver
#2 Posted : Wednesday, February 17, 2021 9:36:27 PM(UTC)
xaver
This should work
install Trial Version on both PCs and test it for free by yourself
brokensword
#3 Posted : Thursday, February 18, 2021 9:37:02 PM(UTC)
brokensword
Originally Posted by: xaver Go to Quoted Post
This should work
Thank you for your answer. I did this and it seems to work fine. I have to learn how to use replays because I didn't find them very intuitive. I used BLT and TRICASTER for replays and they looked a lot simpler.
#4 Posted : Friday, February 19, 2021 12:20:49 AM(UTC)
@ brokensword
This tutorial video might be of assistance:
