Instant Replay
Replay from 2 NDI input to 1 NDI output
Hi I'm new to vMix. I have discovered this wonderful software and would like some information from those who use it. I haven't tried the replays yet but before buying I wanted to know if my need can be solved. I need to have two cameras under replay. The two cameras are connected via SDI to the main PC with vMix. Can I convert the two cameras to NDI to send them to another PC for replays? And can I use the NDI output of replays as input into vMix to go on air?
I hope I explained myself well, sorry for the English but I use google translate. Thanks to everyone in advance.
This should work install Trial Version on both PCs and test it for free by yourself
Originally Posted by: xaver  This should work install Trial Version on both PCs and test it for free by yourself Thank you for your answer. I did this and it seems to work fine. I have to learn how to use replays because I didn't find them very intuitive. I used BLT and TRICASTER for replays and they looked a lot simpler.
Joined: 3/7/2012(UTC) Posts: 2,682  Location: Canada Thanks: 33 times Was thanked: 512 time(s) in 480 post(s)
@ brokensword This tutorial video might be of assistance: Ice
Instant Replay
