Joined: 10/10/2019(UTC) Posts: 59   Location: Düsseldorf Thanks: 3 times Was thanked: 14 time(s) in 8 post(s)
Hi, Ia am using a 27" 4K Display activated the vMix High DPI Display support. https://www.vmix.com/kno...-display-support-in-vmixThe vMix font is now much clearer and better to read and the UI looks good. The only Problem is that the menu font is really small. My Windows 10 font skaling is set to 150%. Is there a way to make the menu font bigger? Here are some screenshots. Regards Michel  vMix1.png (98kb) downloaded 5 time(s). vMix3.png (166kb) downloaded 2 time(s). vMix2.png (143kb) downloaded 2 time(s).
Joined: 7/28/2019(UTC) Posts: 351  Location: Santa Rosa Thanks: 1 times Was thanked: 53 time(s) in 51 post(s)
I run my 28" 4K displays at 175% and they look fine, and VMix is about the right size with custom DPI.
Originally Posted by: Vince Beck  I run my 28" 4K displays at 175% and they look fine, and VMix is about the right size with custom DPI. Will check that, I choose the recommended sacling in windows settings. That is 150% and this setting in the vMix Shortcut. Dis you also change the settings in the shortcut? Because when you don't, then you are running vMix in normal mode with blurry text.  vMix4.png (105kb) downloaded 2 time(s).
