Follo
#1 Posted : Tuesday, February 16, 2021 9:59:11 AM(UTC)
Follo
Germany
Was thanked: 17 time(s) in 10 post(s)
Ia am using a 27" 4K Display activated the vMix High DPI Display support.
https://www.vmix.com/kno...-display-support-in-vmix
The vMix font is now much clearer and better to read and the UI looks good. The only Problem is that the menu font is really small.
My Windows 10 font skaling is set to 150%.
Is there a way to make the menu font bigger?
Here are some screenshots.
Regards
Michel vMix1.png (98kb) downloaded 5 time(s). vMix3.png (166kb) downloaded 2 time(s). vMix2.png (143kb) downloaded 2 time(s).
Vince Beck
#2 Posted : Tuesday, February 16, 2021 10:23:05 AM(UTC)
Vince Beck
I run my 28" 4K displays at 175% and they look fine, and VMix is about the right size with custom DPI.
Follo
#3 Posted : Tuesday, February 16, 2021 7:20:16 PM(UTC)
Follo
Germany
Will check that, I choose the recommended sacling in windows settings. That is 150% and this setting in the vMix Shortcut.
Dis you also change the settings in the shortcut? Because when you don't, then you are running vMix in normal mode with blurry text.
