Just want to know if the AJA KONA 3G will work with vMix...I see the newer card, 3G/Quad. I have an offer to obtain the 3G, that is why I am asking..
Thanking you...
Joined: 8/29/2015(UTC) Posts: 136 Location: Seattle Wa
Thanks: 16 times Was thanked: 14 time(s) in 13 post(s)
yes it works, i have one.
 1 user thanked hellokitty for this useful post.
Thanks...All I will need is the cables....maybe I can get them on Ebay....
I am having issues with my AJA Kona 3G quad capture card....I finally got it to show in vMix, but now I get "initialization failed" every time I try to add an input
need help please
Is there a vMix plugin for the Kona 3G quad....I can not seem to get it to work with my vMix system....
any help I can get will well accepted.
Joined: 2/9/2013(UTC) Posts: 262 Location: Katy, Texas
Using the AJA Software Installer v15.0.1 (this is the last driver that supports Kona 3G directly with firmware updates and everything else) and vMix 24.0.0.46 I can get the Kona 3G card to work with 720P/59.94 and 1080i/59.94, but I can't get it to work with 1080P/59.94.
Although I haven't tried it in awhile, I believe the newer AJA drivers will work, but not for firmware updates/changes.
I an using vMix 23.0.0.36, but every time I see the card, and I connect an input, the card just disappears from vMix inputs, when I check the device Manager, the card sometimes is still there, or it may have a yellow mark on it.....restart the PC, and everything is looking good again, then, the same thing happens again.... Really need some hekp here...AJA support tried to help, but no luck...they even had full remote control of my PC..
Joined: 10/24/2020(UTC) Posts: 21  Location: CA Thanks: 10 times Was thanked: 2 time(s) in 2 post(s)
What are your system specs?
Make sure you're using a PCIe slot that is electrically compatible with the card (PCIe 2.0 x8 I believe)
I've been running two KONA 3Gs in three separate systems without much issue since lockdown.
I am using an Asus H87M-PRO with just 16 gigs of ram....this board a PCIe slot running at x4, is where I have the card inserted, the other slot x16, is used by the video card......
