Dropped frames in external rendering
Rank:: Newbie
Hi, (sorry for my English) I have a problem with external rendering with my DeckLink Mini Monitor. In the External information window I get this info:"Dropped Frames Due to hard disc/CPU - 78904032" (etc. still growing), "Jitter - -40" I don't know what's up, please for help. This is my system: Windows 7 Home Premium 64 bit Procesor: AMD A10-5800 APU with Rodeon HD Graphics 3.80 GHz Ram: 12 GB DDR3 Grapphics: NVIDIA GeForce GTX 550 Ti HD: Samsung 500 GB for system & video :( External renderer: Black Magic Deck Link Mini Monitor (via HDMI signal goes to DATAVIDEO NVS-20 Encoder & Streaming Server)
Bless & Regards, adam (from Poland ;-) )
Joined: 2/6/2011(UTC) Posts: 79  Location: Belgium Thanks: 1 times Was thanked: 3 time(s) in 3 post(s)
it looks like either your CPU, either you hard disc isn't up to the task... I think the processor is OK, so the problem might be your disc
Thanks: 5 times Was thanked: 18 time(s) in 18 post(s)
Dear Adam
Your CPU is a quad core, and if you are using a add on grafic card (as I see in your message) he can do the job if you are not stressing the Computer with other task. So monitor your unit for hardware and cpu usage without using vmix at all, and see if you did have a low level of cpu usage or not. Your HDD, if it's a new one cannot be the issue, only if something are continuosly call it for great data exchange. In that case, upgrade for a SSD one. I will advice you to use your unit for production with vmix only without using it for other process, if you use your computer for other things also Are you streaming in SD or HD, try SD to see if the same issue occur
Rgds
C.
Joined: 1/13/2010(UTC) Posts: 5,344  Location: Gold Coast, Australia Was thanked: 4746 time(s) in 1631 post(s)
Your specs seem more than capable of sending the external output. My guess is the frame rate you have set for External Output is different to the frame rate in the Display tab of vMix settings. These both need to match in order for there not to be any dropped frames.
Also, check the following:
1. Render Time at the bottom of vMix, if this is above 20ms then the graphics card is unable to keep up. 2. Check the audio device in vMix Settings -> External Output if used is set to Decklink Audio Render. 3. In the control panel -> hardware and sound, make sure the output is not set to a decklink device as this will interfere.
Martin vMix
Rank:: Newbie
Thanks for All the answers. I bought a new 1TB Hard Disc for video (WD - 7200pm - 64 MB). The problem still is. Now, "dropped frames" begins after 1-2 hours of work vmix, before this time all is well. I did everything you said Martin. At the bottom I see this info: EX Fps: 25 Render Time: 7 ~ 21ms (more is under 20) CPU: 17 ~ 21%
Regards, adam
