Is there a Shortcut to tick/untick Multiview Sources?
Joined: 8/2/2013(UTC) Posts: 1,096   Location: Fairhope, Alabama USA Thanks: 587 times Was thanked: 202 time(s) in 168 post(s)
Perhaps I'm missing it, but is there a shortcut to tick/untick individual input sources in a multiview?
- Tom
Joined: 12/27/2012(UTC) Posts: 5,509  Location: Belgium Thanks: 316 times Was thanked: 1020 time(s) in 838 post(s)
Originally Posted by: sinc747  Perhaps I'm missing it, but is there a shortcut to tick/untick individual input sources in a multiview?
- Tom LayerOnOff ? FYI v24 gives the ability to search for a shortcut ;-)
Joined: 10/6/2020(UTC) Posts: 98  Was thanked: 21 time(s) in 21 post(s)
Yup, use these shortcuts quite a bit :
MultiViewOverlay - Toggle On/Off MultiView Overlay For Input At Index (starting from 1) or MultiViewOverlayOff / MultiViewOverlayOn
 1 user thanked matkeane for this useful post.
Mind you
Multiview has been renamed to Layers to avoid confusion with the Output Multiviews (settings) in v24 hence currently the 2 options in v24 (multiview (old) and layeronoff (new)) were both are usable
Originally Posted by: doggy  Mind you
Multiview has been renamed to Layers to avoid confusion with the Output Multiviews (settings) in v24 hence currently the 2 options in v24 (multiview (old) and layeronoff (new)) were both are usable Ah, thanks, that's good to know. I haven't played with v24 yet. Looking at the docs (https://www.vmix.com/help24/), it might be good if the new Layer commands were mentioned in, or linked from, the older MultiViewOverlay commands. Anyway, it's good to hear vMix are making some of the terminology less confusing...
Originally Posted by: matkeane  Ah, thanks, that's good to know. I haven't played with v24 yet. Looking at the docs (https://www.vmix.com/help24/), it might be good if the new Layer commands were mentioned in, or linked from, the older MultiViewOverlay commands.
Also helpfull is checking the New Features and Changes : Input MultiView renamed Input Layers to make it easier for new users. New shortcut names added as well, with old shortcuts kept for backwards compatibility.
Thank you! - Tom
