CREATIVESABOTEUR
#1 Posted : Thursday, February 11, 2021 10:02:47 AM(UTC)
CREATIVESABOTEUR
Trying to use VST3 plugins for first time. Placed them in Program/Common Files/VST 3
When adding a plugin to a source the plugins are in the drop down list, but when selected I get the error message: "Couldn't configure plugin"
So, what do I do now?
#2 Posted : Thursday, February 11, 2021 12:59:24 PM(UTC)
VST3 plugins come with an installer so they are installed correctly.
If you copied some files manually chances are it is actually a VST1 or VST3 plugin and not supported.
eduardocfs on 2/12/2021(UTC)
CREATIVESABOTEUR
#3 Posted : Friday, February 12, 2021 12:45:41 PM(UTC)
CREATIVESABOTEUR
There was no installer. Just zip file that extracts to include folder and files for plugin. How do I install these then?
CREATIVESABOTEUR
#4 Posted : Friday, February 12, 2021 1:34:30 PM(UTC)
CREATIVESABOTEUR
Got other plugins to work. Problem solved. Thanks.
I copy the plugin into Program/Common Files/VST3
