Rinsky
#1 Posted : Wednesday, February 10, 2021 1:39:03 AM(UTC)
Rinsky
Here are ssome things that are still missing in the new IR to have the most flexible workflows possible:
1. highlight active channel(s) with a indicator around the monitor windows (already mentioned in a previous post)
2. make it possible to create an event by pressing "mark out" first (already mentioned in a previous post)
3. there is no shortcut for "swap cameras between A and B"
4. there need to be more transition options than just a simple cut
5. there also needs to be a "automatically play with transition" option between A and B
6. channel control needs to stay with the "active" channel/active channel needs to be swapped as well
7. ability to uncheck all camera angles to choose the camera angles by just clicking on the A or B camera angle buttons.
Advanced/professional Workflow would be like this for example:
Events happens -> "Mark Out" -> Scroll back to the desired In Point and "Mark In" -> choose camera angle for Channel A -> Playback Channel A -> go to Channel B -> choose camera angle for Channel B and find the right in point -> wait until camera angle from channel A is finished and then swap/cut/fade/auto to channel B with different camera angle
The great thing about it is, that this way a completely professional and fast workflow would be possible and afterwards you could always create cliplists/playlists/highlight reels in a different event folder and then check the camera angles you want to have and copy the events etc. to make a playlists for intermissions or the end of the game.
Btw: I was working with the X-Keys Replay controller and I am still looking to find the perfect setup for it. Will share it when the new replay system is finished and me shortcut/button configuration setup is also done.
thanks 2 users thanked Rinsky for this useful post.
stevespaw on 2/11/2021(UTC), pm on 2/11/2021(UTC)
stevespaw
#2 Posted : Thursday, February 11, 2021 4:17:23 AM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
+1
pm
#3 Posted : Thursday, February 11, 2021 4:48:32 AM(UTC)
pm
Was thanked: 33 time(s) in 28 post(s)
+1
absolutely necessary for a professional workflow in fast-paced sports productions!
krassesPferd
#4 Posted : Thursday, February 11, 2021 5:01:50 AM(UTC)
krassesPferd
Was thanked: 8 time(s) in 7 post(s)
This is already possible. Simply create "MarkIn", go backwards and create "MarkOut". vMix will automatically swap the two points and create your clip.
thanks 1 user thanked krassesPferd for this useful post.
Rinsky on 2/11/2021(UTC)
stigaard
#5 Posted : Thursday, February 11, 2021 5:42:02 AM(UTC)
stigaard
Denmark
+1
