vMix Call
Vmix Call Scripting Question
Joined: 11/20/2020(UTC) Posts: 74   Thanks: 13 times Was thanked: 9 time(s) in 9 post(s)
Hi Together,
I am still a dummy to scripting so here my question:
Can I check the status of any of my Vmix Calls and is status is "connected" automatically open the Call Manager?
I am handling multiple Callers and inputs and would like to get kind of a signal when a caller logs in to become aware "there is somebody new".
Thanks in advance for a scripting hint.
Originally Posted by: Chris Daum  Can I check the status of any of my Vmix Calls Yes, by reading the callConnected status from the API XML for a call input Quote: is status is "connected" automatically open the Call Manager?
No afaik, but the script could do that for you Quote: I am handling multiple Callers and inputs and would like to get kind of a signal when a caller logs in to become aware "there is somebody new".
no need for the Call manager for that to pop up each time but you could create title input to show which callers inputs are connected through the script that "constantly" checks for: see point one or let it make a sound to warn you or .... Check "scripting for dummies" topic in the forum for how to check stuff in the API XML One could also populate a XML data source with just the calls in the table or the ones that are connected only etc
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
There is also this option: https://forums.vmix.com/...x-23-Changelog#post76338* Added "Enable Notifiation Sounds" checkbox in Settings -> Audio This currently enables the Windows system defined "New Text Message Notification" sound when new chat messages are received for vMix Call If you are monitoring vMix audio through the same audio output Windows uses for the notifications, you will notice when someone connects.
 1 user thanked dmwkr for this useful post.
vMix Call
