Chris Daum
#1 Posted : Wednesday, February 10, 2021 7:52:36 PM(UTC)
Chris Daum
Germany
Hi Together,
I am still a dummy to scripting so here my question:
Can I check the status of any of my Vmix Calls and
is status is "connected" automatically open the Call Manager?
I am handling multiple Callers and inputs and would like to get
kind of a signal when a caller logs in to become aware "there is somebody new".
Thanks in advance for a scripting hint.
#2 Posted : Wednesday, February 10, 2021 8:14:20 PM(UTC)
Yes, by reading the callConnected status from the API XML for a call input
No afaik, but the script could do that for you
no need for the Call manager for that to pop up each time but you could create title input to show which callers inputs are connected through the script that "constantly" checks for: see point one
or let it make a sound to warn you or ....
Check "scripting for dummies" topic in the forum for how to check stuff in the API XML
One could also populate a XML data source with just the calls in the table or the ones that are connected only etc
dmwkr
#3 Posted : Wednesday, February 10, 2021 11:56:15 PM(UTC)
dmwkr
There is also this option:
https://forums.vmix.com/...x-23-Changelog#post76338
* Added "Enable Notifiation Sounds" checkbox in Settings -> Audio
This currently enables the Windows system defined "New Text Message Notification" sound when new chat messages are received for vMix Call
If you are monitoring vMix audio through the same audio output Windows uses for the notifications, you will notice when someone connects.
thanks 1 user thanked dmwkr for this useful post.
Chris Daum on 3/22/2021(UTC)
