kevinmclane
#1 Posted : Wednesday, February 10, 2021 3:28:07 AM(UTC)
kevinmclane
I would like to have an input trigger to select an item of a list as "current".
Thanks,
Kevin
#2 Posted : Wednesday, February 10, 2021 3:47:41 AM(UTC)
Thanks,
Kevin
Can you explain a little more in depth please
kevinmclane
#3 Posted : Wednesday, February 10, 2021 4:59:11 AM(UTC)
kevinmclane
Hi Doggy,
The case example involves lower third video files in a "list input". When I take a camera input live, I would like to select an item in the list (correct lower third for that presenter). Then, when I send the list to an overlay bus I always have the correct lower third.
I am currently doing this with input triggers to add the lower third video to my list when the matching camera OnTransitionIn (delay 500ms), and then remove the video index 1 OnTransitionOut (delay 0ms) to make sure I don't cause a race condition since adding refers to file path and removal refers to the item index.
My feature request is a trigger that can mark a list item as current. Same functionality as a double click on the list item in the list panel. This way I am not typing out complete file paths to my trigger every time. Potentially just a "set list item" trigger and what item from a dropdown.
Thanks,
Kevin
#4 Posted : Wednesday, February 10, 2021 5:25:47 AM(UTC)
to be sure i understand: you activate a camera and want the matching presenter data LT to respond
Why do these lower thirds have to be video files and not simply vMix titles ?
Would make live so much easier
could then use presets or Scripting (one script) to figure out the correct title content based on the live video (various options) etc ( about how many cameras/ presenter data is one talking about ? )
dmwkr
#5 Posted : Wednesday, February 10, 2021 6:06:24 AM(UTC)
dmwkr
Was thanked: 153 time(s) in 137 post(s)
Isn't SelectIndex the function the OP is looking for?
kevinmclane
#6 Posted : Wednesday, February 10, 2021 6:33:24 AM(UTC)
kevinmclane
Hi Doggy, I agree with you but the client wanted to create them instead.
dmwrk, thank you. This is what I was looking for. You can close this request.
