Joined: 7/7/2020(UTC) Posts: 25  Location: New Jersey
I've been noticing that my bandwidth for available incoming vMix Call has been very low and after doing some digging, I see that at idle, with no external outputs going, my vMix is taking up a huge amount of CPU 16%, Memory 27% and Network 22%. Power usage is shown as being Very High.
Sounds to me like something is not correct here and I wanted to see if anyone has any thoughts on why my vMix machine would be sucking up so much Network usage at idle? I do have NDI turned on for my four Outputs, but no other NDI enabled.
Thoughts?
Every NDI Output that is used outside your VMIX machine uses about 100MBit of your network bandwith. So 4 active outputs use up to 400MBit - that would be nearly half the bandwith of your 1GBit network port.
Change your network cards to 10GBit or use something different than NDI.
Cheers
pro
