Welcome Guest! To enable all features please Registers on the forum or Registers.
thom0422
#1 Posted : Monday, February 8, 2021 3:29:39 AM(UTC)
thom0422
I've been noticing that my bandwidth for available incoming vMix Call has been very low and after doing some digging, I see that at idle, with no external outputs going, my vMix is taking up a huge amount of CPU 16%, Memory 27% and Network 22%. Power usage is shown as being Very High.
Sounds to me like something is not correct here and I wanted to see if anyone has any thoughts on why my vMix machine would be sucking up so much Network usage at idle? I do have NDI turned on for my four Outputs, but no other NDI enabled.
Thoughts?
streaming---pro
#2 Posted : Monday, February 8, 2021 6:35:18 PM(UTC)
streaming---pro
Germany
Every NDI Output that is used outside your VMIX machine uses about 100MBit of your network bandwith. So 4 active outputs use up to 400MBit - that would be nearly half the bandwith of your 1GBit network port.
Change your network cards to 10GBit or use something different than NDI.
Cheers
pro
