3 Pages<123
timmy
#41 Posted : Wednesday, January 27, 2021 4:44:47 AM(UTC)
timmy
+1 for sure!
jrodjared
#42 Posted : Monday, February 8, 2021 11:35:56 AM(UTC)
jrodjared
+1
This is like having every IP address set with DHCP. It's impossible to link anything to an input (like a controller).
FastForward
#43 Posted : Wednesday, February 10, 2021 8:44:38 PM(UTC)
FastForward
Germany
+1
SuperBill
#44 Posted : Thursday, February 11, 2021 9:06:32 AM(UTC)
SuperBill
Canada
Adding my voice +100 !
the panel display order should not affect the input assignments or references, time to add that as a separate db column.
vmix is awesome btw ! Coming from a Tricaster world - why did I even bother, and looking at OBS what a disaster (good for super basic things)
djones02
#45 Posted : Wednesday, May 12, 2021 8:37:51 AM(UTC)
djones02
Canada
Just got my xkeys and am trying to setup a workflow but things keep moving around. Very frustrating.
I would like to be able to set a shortcut to the first input in a category and of course have them not move.
My setup has black show all inputs.
Red - Cameras
Green - layouts
Yellow - content
Magenta - Music
Blue - Transitions stingers
Purple - overlays
I set buttons to play/pause music, advance slides, queue up videos.
Adding or moving inputs throws off the shortcuts and macros.
I noticed dragging and dropping an input onto another one puts them in sequential order.. drag 13-Camera1 onto 2-Layout1 and it becomes 2-Camera1 3-Layout1 and all the other inputs get rearranged.
At the very least I should be able to lock inputs and drag and drop should swap input numbers.
danhoff
#46 Posted : Thursday, June 3, 2021 8:21:50 AM(UTC)
danhoff
+1
BAU
#47 Posted : Thursday, June 10, 2021 10:04:05 AM(UTC)
BAU
MickeyMJJ
#48 Posted : Friday, June 11, 2021 10:01:20 PM(UTC)
MickeyMJJ
+1
Chris Daum
#49 Posted : Friday, June 11, 2021 10:31:26 PM(UTC)
Chris Daum
Germany
wouldn´t it be possible to use wether the input key or title in your presets?
Cause these are independent of the input number.
Read from XML:
Code:
<vmix>
<version>24.0.0.58</version>
<edition>4K</edition>
<preset>C:\Users\epicto\AppData\Roaming\last.vmix</preset>
<inputs>
<input key="d76d8d80-8710-40a2-bcf3-8acc210d8c2b" number="1" type="VideoCall" title="Call 1" shortTitle="Call 1" state="Running" position="0" duration="0" loop="False" muted="True" volume="100" balance="0" solo="False" audiobusses="B" meterF1="0" meterF2="0" gainDb="0" callPassword="7001325668" callConnected="False" callVideoSource="Output1" callAudioSource="Master">
would be (fade in In1 on main output, as an example)
Code:
api.function:("fade", input:="d76d8d80-8710-40a2-bcf3-8acc210d8c2b", mix:=0")
or
Code:
api.function:("fade", input:="Call 1", mix:=0")
instead of
Code:
api.function:("fade", input:=1, mix:=0")
AgentPete
#50 Posted : Saturday, June 12, 2021 12:00:54 AM(UTC)
AgentPete
Was thanked: 9 time(s) in 3 post(s)
+1
kroskopf
#51 Posted : Saturday, June 12, 2021 1:50:07 AM(UTC)
kroskopf
Streamverse.tv
#52 Posted : Tuesday, September 7, 2021 2:15:09 AM(UTC)
Streamverse.tv
Austria
I've had the need for this too. This is my idea on how this can be implemented:
I've created this example project to visually show what I mean:
Output 2 is configured to always display Input 4:
Example
To prevent the Inputs to rearrange, right-clicking the Input Number would lock it:
Locked Input
When Input 3 gets closed, a Blank would take its place. So, Input 4 can stay at #4.
Blank gets inserted
SportsNetUSA.net
#53 Posted : Tuesday, September 7, 2021 3:59:40 AM(UTC)
SportsNetUSA.net
+1
Tone13
#54 Posted : Thursday, September 16, 2021 3:16:54 PM(UTC)
Tone13
+1
Can't believe this still hasn't been fixed. It's so easy to break things with the current way inputs are handled. Was hoping vMix 24 had addressed this but it seems no ....Urgh
Fbcgulfport
#55 Posted : Thursday, December 29, 2022 9:23:21 AM(UTC)
Fbcgulfport
+1
Peter Berglund
#56 Posted : Monday, January 2, 2023 8:57:20 PM(UTC)
Peter Berglund
Sweden
+1
Please make it possible to assign/lock a number to a specific input. I have had issues when you "break the chain" and really mess things up - especially when you have surfaces like Skaarhoj panels configured to specific input numbers for audio and other stuff. I have kindly asked a Skaarhoj for a feature request where vMix inputs could be recognized in Reactor by means of input names rather than input numbers as a workaround. Not sure if they will manage that challenge...
/Peter
bbbullock
#57 Posted : Saturday, June 3, 2023 5:12:21 PM(UTC)
bbbullock
See also my request to make the actual movement and management of inputs easier. So much room for improvement!
https://forums.vmix.com/...o-moving-managing-Inputs
IainJC
#58 Posted : Friday, April 26, 2024 6:48:11 AM(UTC)
IainJC
+1 to locking input numbers or removing the need to use that to identify an input - use something 'static' instead
#59 Posted : Friday, April 26, 2024 6:57:58 AM(UTC)
an input's name is static so is its key (from the API)
fgolman
#60 Posted : Wednesday, October 30, 2024 10:44:38 AM(UTC)
fgolman
+1
3 Pages<123
