GT
Revers timer from external data
Hello, I am looking for a solution to the next task! We receive external data of the timer using the JSON protocol in the format (mm: ss). But the problem is that the countdown goes to 00:00, and I need to unfold it and so that the timer from 00:00 is displayed in the graph. I would be very grateful for a ready-made solution.
Originally Posted by: tvandrey  the problem is that the countdown goes to 00:00, isn't that what a countdown normally does ? Quote: and I need to unfold it and so that the timer from 00:00 is displayed in the graph. what do you mean by unfold and graph ?
The timer runs from 30:00 to 00:00(this is the judging system) , but in the title it must be start from 00:00 to 30:00
Joined: 2/2/2021(UTC) Posts: 14  Location: Moscow Region Thanks: 5 times
Originally Posted by: tvandrey  The timer runs from 30:00 to 00:00(this is the judging system) , but in the title it must be start from 00:00 to 30:00 This can be done using the Scoreboard OCR program and the script for it.
Originally Posted by: Vyacheslav  This can be done using the Scoreboard OCR program and the script for it.
That's a pretty expensive solution just to invert a time while the official time is already presented through a json file no matter what one uses to invert that time it will create a delay due to recalculations and putting it back in a title the simplest way is to put that Json time ( pulled from data source) in a title (hidden) and have a script read that and use the formula 30:00 - Json time and put that back in your title
GT
