tvandrey
#1 Posted : Wednesday, January 13, 2021 11:15:21 PM(UTC)
tvandrey
Belarus
Hello, I am looking for a solution to the next task! We receive external data of the timer using the JSON protocol in the format (mm: ss). But the problem is that the countdown goes to 00:00, and I need to unfold it and so that the timer from 00:00 is displayed in the graph. I would be very grateful for a ready-made solution.
#2 Posted : Thursday, January 14, 2021 12:57:43 AM(UTC)
isn't that what a countdown normally does ?
what do you mean by unfold and graph ?
tvandrey
#3 Posted : Thursday, January 14, 2021 6:27:32 AM(UTC)
tvandrey
Belarus
The timer runs from 30:00 to 00:00(this is the judging system) , but in the title it must be start from 00:00 to 30:00
Vyacheslav
#4 Posted : Sunday, February 7, 2021 7:18:26 AM(UTC)
Vyacheslav
Russian Federation
This can be done using the Scoreboard OCR program and the script for it.
#5 Posted : Monday, February 8, 2021 1:34:05 AM(UTC)
That's a pretty expensive solution just to invert a time while the official time is already presented through a json file
no matter what one uses to invert that time it will create a delay due to recalculations and putting it back in a title
the simplest way is to put that Json time ( pulled from data source) in a title (hidden) and have a script read that and use the formula 30:00 - Json time and put that back in your title
