untledean
#1 Posted : Saturday, February 6, 2021 11:29:21 PM(UTC)
untledean
I use PowerPoint for 2 line lyrics at the bottom of the screen. I create this by making a narrow slide in PPT. But when I add the input in vMix it is full screen. I have to narrow it back down to 2 lines. I leave the width full screen. I set "Zoom Y" manually to get to the 2 line size. I then bring it in as an overlay.
I can do it manually but it would be simpler if I could use a shortcut. There is already a shortcut for "Pan X and Pan Y". Could this be done for SetZoom?
#2 Posted : Saturday, February 6, 2021 11:55:07 PM(UTC)
Was thanked: 1011 time(s) in 832 post(s)
1. have you tried changing the Aspect ratio of your input ?
2. would it not be simpler to have a correct size (ration) of the slides ?
untledean
#3 Posted : Sunday, February 7, 2021 12:00:56 AM(UTC)
untledean
Yes, Anamorphic is the only one that does not go to full screen. I even tried creating the PPT as a banner and it still imports full.
#4 Posted : Sunday, February 7, 2021 12:05:51 AM(UTC)
What about using titles ?
untledean
#5 Posted : Sunday, February 7, 2021 12:17:10 AM(UTC)
untledean
Are you speaking of a vMix title or a PPT title?
If vMix, these are song lyrics over several slides and have to be changed quickly. It wouldn't be feasible to use titles.
If PPT, it does same thing. Where else can I stop it from importing as full screen? Can it be imported as an overlay?
untledean
#6 Posted : Sunday, February 7, 2021 1:50:00 AM(UTC)
untledean
doggy,
After your questions, I did some more research and have found a work-around. If I save the slides as jpegs, I can input the folder and work it as pictures. The size is just as it is in PPT. All I have to do is make a quick pan setting (which I can do with a trigger) to take it to the bottom of the screen. It also has a smaller footprint than the PPT slides and loads faster. The load time gets pretty long when there are 40-50 slides in the PPT.
Thanks for your help!
#7 Posted : Sunday, February 7, 2021 1:54:33 AM(UTC)
not feasible ? maybe check out using data sources in titles where you can advance a row of data with a single keypress, how much quicker can you get :-)
One title, one simple data file containing all the lyrics and one shortcut no messing around with panning and moving an image
Guest (7)
Similar Topics
Virtual Set Zoom Reset after Transition Out (General Discussion)
Belarus ccolewilliam 10/2/2020 1:48:58 AM(UTC)
Shortcuts for Virtualset Zooms (General Discussion)
by tvfabrik 7/14/2020 11:43:03 PM(UTC)
virtual set zoom in and out speeds (General Discussion)
by Len56 10/7/2015 2:17:09 PM(UTC)
[DOWNLOAD LINK] VirtualSet Zooms (General Discussion)
by Thremir 6/18/2014 2:36:07 PM(UTC)
