New To scripting - Transition based on active input
Thanks: 16 times Was thanked: 11 time(s) in 9 post(s)
I wonder if this is possible? If the active input is X, then if I transition to X use merge not cut direct
I want to merge transitions away and into certain inputs, but I am a silo producer and my control surface is very much the cut direct way of working.
I have some knowledge of coding but I'm not a pro.
Thanks in advance.
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Check what changes in the API XML and base any script of function on that to achieve what you like to happen . check the "scripting for dummies" topic
