nowski
#1 Posted : Saturday, February 6, 2021 12:58:00 AM(UTC)
nowski
I wonder if this is possible?
If the active input is X, then if I transition to X use merge not cut direct
I want to merge transitions away and into certain inputs, but I am a silo producer and my control surface is very much the cut direct way of working.
I have some knowledge of coding but I'm not a pro.
Thanks in advance.
#2 Posted : Saturday, February 6, 2021 3:39:37 AM(UTC)
Check what changes in the API XML and base any script of function on that to achieve what you like to happen . check the "scripting for
dummies" topic
