Joined: 6/6/2020(UTC) Posts: 8  Location: Minnesota Thanks: 6 times
I noticed that Vmix deposited the app in my documents folder not in the C:
Its a big file not a shortcut so I dare not touch it, but would not like it in my documents folder... Why does it do this? Can I delete or move this?
Joined: 7/28/2019(UTC) Posts: 351  Location: Santa Rosa Thanks: 1 times Was thanked: 53 time(s) in 51 post(s)
You are seeing the previous version(s) installer after an update. That way if you have issues after an update, you can always re-install a previous version. You can move it anywhere you like, or delete it if you're sure you don't want to go back.
 1 user thanked Vince Beck for this useful post.
