GT
Automatic title transition IN/OUT when data changes
Joined: 2/2/2021(UTC) Posts: 14  Location: Moscow Region Thanks: 5 times
Friends, I would very much like to implement the function of automatic appearance of the title when data is received in vmix. An example can be seen in this video. I hope you will support me, and the developers will hear us. In the GT Designer already has a similar function: DATA CHANGE IN / DATA CHANGE OUT - which animates the text when data arrives. More information about it is described in this lessonBut I would like to add a function that would work as follows: when the data change, the title automatically made "transition in" and after a specified time was "transition out".
Joined: 12/27/2012(UTC) Posts: 5,475  Location: Belgium Thanks: 313 times Was thanked: 1013 time(s) in 832 post(s)
specify the animation on all the elements or layer you want to move OnDataChangeOut (the data field you want it to react to) do a : 1. Fly arrow up with a delay it has to remain in view set to reverse 2. Fly arrow Up no delay will have to use a mask for the out of view part and add a hide first on transition in animation Click image to see animation  box.gif (127kb) downloaded 92 time(s).
Originally Posted by: doggy  Originally Posted by: Vyacheslav  Friends, I would very much like to implement the function of automatic appearance of the title when data is received in vmix. An example can be seen in this video. I hope you will support me, and the developers will hear us. In the GT Designer already has a similar function: DATA CHANGE IN / DATA CHANGE OUT - which animates the text when data arrives. More information about it is described in this lessonBut I would like to add a function that would work as follows: when the data change, the title automatically made "transition in" and after a specified time was "transition out". specify the animation on all the elements or layer you want to move with OnDataChange1 (the data field you want it to react to) do a : 1. Fly up with a delay it has to remain in view 2. Fly Up set to reverse no delay will have to use a mask for the out of view part Only this element should move.  I think that in the GT Designer program, it should look like this:
Originally Posted by: Vyacheslav  Only this element should move.  Did you click on the image i posted ? it's a animated gif (have to click on it first) of a video doing exactly that in a GT title based on the datachange of the textbox !! Quote:I think that in the GT Designer program, it should look like this:  Why ? When one already can do this in the GT title designer? PS Don't use the term transition , these are animations in a title
Originally Posted by: doggy  Originally Posted by: Vyacheslav  Only this element should move.  Did you click on the image i posted ? it's a animated gif (have to click on it first) of a video doing exactly that in a GT title based on the datachange of the textbox !! Quote:
I'm sorry, I didn't see the animation earlier. How did you do it??? Tell us more. If it can be shown on the video, I will be very grateful.
Originally Posted by: doggy   boxappear.JPG (256kb) downloaded 64 time(s). Doggy many thanks! Please tell me how to make a mask correctly???
Create rectangle (or any other element) add second rectangle (partially over first rectangle) select rectangle 1 and choose for mask the second rectangle (effects tab) set second rectangle opacity to 0
any part of first rectangle that is within the second one's boundary will be shown
BTW a good thing you added a video as the post description did NOT reflect the goal at all
Originally Posted by: doggy  Create rectangle (or any other element) add second rectangle (partially over first rectangle) select rectangle 1 and choose for mask the second rectangle (effects tab) set second rectangle opacity to 0
Thank you very much! Originally Posted by: doggy  BTW a good thing you added a video as the post description did NOT reflect the goal at all
How can I better describe the post?
The title is already in view( has appeared) , you wanted an element of the title to appear based on a datachange ;-)
Doggy thank you very much, everything works! If someone did not understand how to make such a title, I posted a video with an example and a gtzip file.
GT
