Vyacheslav
#1 Posted : Wednesday, February 3, 2021 10:10:58 PM(UTC)
Vyacheslav
Russian Federation
Friends, I would very much like to implement the function of automatic appearance of the title when data is received in vmix. An example can be seen in this video.
I hope you will support me, and the developers will hear us.
In the GT Designer already has a similar function: DATA CHANGE IN / DATA CHANGE OUT - which animates the text when data arrives. More information about it is described in this lesson
But I would like to add a function that would work as follows: when the data change, the title automatically made "transition in" and after a specified time was "transition out".
Example
#2 Posted : Thursday, February 4, 2021 4:40:15 AM(UTC)
specify the animation on all the elements or layer you want to move
OnDataChangeOut (the data field you want it to react to) do a :
1. Fly arrow up with a delay it has to remain in view set to reverse
2. Fly arrow Up no delay
will have to use a mask for the out of view part and add a hide first on transition in animation
Click image to see animation
Vyacheslav on 2/6/2021(UTC)
Vyacheslav
#3 Posted : Thursday, February 4, 2021 5:33:39 AM(UTC)
Vyacheslav
Russian Federation
specify the animation on all the elements or layer you want to move with
OnDataChange1 (the data field you want it to react to) do a :
1. Fly up with a delay it has to remain in view
2. Fly Up set to reverse no delay
Only this element should move.
I think that in the GT Designer program, it should look like this:
#4 Posted : Thursday, February 4, 2021 5:28:38 PM(UTC)
Did you click on the image i posted ? it's a animated gif (have to click on it first) of a video doing exactly that in a GT title based on the datachange of the textbox !!
Why ? When one already can do this in the GT title designer?
PS Don't use the term transition , these are animations in a title
Vyacheslav
#5 Posted : Thursday, February 4, 2021 6:02:42 PM(UTC)
Vyacheslav
Russian Federation
I'm sorry, I didn't see the animation earlier. How did you do it??? Tell us more. If it can be shown on the video, I will be very grateful.
#6 Posted : Thursday, February 4, 2021 6:16:54 PM(UTC)
Vyacheslav
#7 Posted : Thursday, February 4, 2021 7:05:45 PM(UTC)
Vyacheslav
Russian Federation
Doggy many thanks! Please tell me how to make a mask correctly???
#8 Posted : Thursday, February 4, 2021 7:47:43 PM(UTC)
Create rectangle (or any other element)
add second rectangle (partially over first rectangle)
select rectangle 1 and choose for mask the second rectangle (effects tab)
set second rectangle opacity to 0
any part of first rectangle that is within the second one's boundary will be shown
BTW a good thing you added a video as the post description did NOT reflect the goal at all
Vyacheslav
#9 Posted : Friday, February 5, 2021 8:31:19 PM(UTC)
Vyacheslav
Russian Federation
Thank you very much!
How can I better describe the post?
#10 Posted : Friday, February 5, 2021 8:44:08 PM(UTC)
The title is already in view( has appeared) , you wanted an element of the title to appear based on a datachange ;-)
Vyacheslav
#11 Posted : Saturday, February 6, 2021 1:25:15 AM(UTC)
Vyacheslav
Russian Federation
Doggy thank you very much, everything works! If someone did not understand how to make such a title, I posted a video with an example and a gtzip file.
Guest (4)
