mstrong
#1 Posted : Monday, March 31, 2014 11:35:38 AM(UTC)
mstrong
I'm trying to broadcast and record our church services with some of the overlay features of vMix. We had a Kworld DVD Maker USB 2.0 that was working ok, but it quit and the replacement one didn't work too well (jumpy video). I purchased a Dell branded ATI Theatre 550 TV tuner card in hopes that it would work with vMix since our church is on a tight budget.
vMix does recognize the card in the list of capture devices when I add an input. However, when I add it, it just shows a black screen. The advanced properties of the ATI AVStream Analog Capture shows that it detects a signal on the Video Decoder tab with 525 lines detected. I have Flash Media Live Encoder installed for the streaming, and when I open it separately, it recognizes the capture card and it displays the camera feed properly. So I know the feed is coming in properly and the drivers seem to be correct. I just can't get vMix to decode the camera feed.
I've tried to match the settings that are similar to vMix and FMLE such as Resolution: 720x480, System: NTSC 59.94i or 29.97p, Input: S Video, Video Format: Default
Again, these settings work well in FMLE, but I just get a black screen in vMix. I would think that since vMix recognizes the device, and FMLE displays this video feed, that vMix should be able to as well. That could just be a wrong assumption though and that's why I'm here. Anyone know?
System: Windows 8.1 x64, 24GB RAM, AMD A8-5500 3.2GHz, 1.5TB HDD
mstrong
#2 Posted : Monday, March 31, 2014 11:45:42 AM(UTC)
mstrong
One thing I just noticed:
FMLE lists the format as H.264
vMix gives an error with H264:
Capture Resolution is not supported by this device.
AddNewInput.The following are supported:
720x480 NTSC 59.94i or 29.97p YUY2
720x240 NTSC 59.94p YUY2
720x576 PAL 50i or 25p YUY2
720x288 PAL 50p YUY2
Unspecified error
Picked 29.97p YUY2 and I don't get an error, but I still don't get video.
Charssay
#3 Posted : Tuesday, April 1, 2014 7:16:35 AM(UTC)
Charssay
Hello mstrong
The ATI 550 is an old card, I think that even the drivers is a windows one since Ati do not have made it for Windows 8 or 7. (If I do not mistake)
The issue is related to the chipset of this card, (it's the same structure - not name), using on old Hauppauge and Avermedia embedding hardware decoder working well with other software but never with Vmix
Since your church is tight on budget, I will advice you to use this card
http://www.amazon.com/Av...MTVHDDVRR/dp/B002SQE1O0/
It's cheap and will give you a better quality and you can even use two Vcamera one in Hdmi and the other in RCA or Svideo. Adding another one you can even use 4 Vcamera
Rgds
C.
mstrong
#4 Posted : Monday, April 7, 2014 11:22:45 PM(UTC)
mstrong
Charssay wrote:
Hello mstrong
Rgds
C.
Took your advice, got this card and was able to test it out today. Works well and also seems to be better quality than the other card I had, plus it allows us to expand in the future! Thanks a lot!
