Streaming into vMix Using GoPro Hero 3
Thanks: 4 times Was thanked: 3 time(s) in 3 post(s)
Hi Forum - I'm looking for a small fixed camera to include in a broadcast, but it's remote so use of a capture card is out of question.
From what I read, it'd be a kluge trying to get a GoPro to stream effectively, but wanted to make sure I'm not missing something. I'm fine with using an intermediary like Wowza, but looks like limitations prevent Hero 3 from pushing RTMP to a server (i.e. Wowza), or having RTSP pulled from it (i.e. vMix Stream input). I also read a post that the Hero 3 limits it's http streaming to 320x240 over WiFi, which is hard to believe but would be nice to confirm / deny.
More generally, any recommendations for a setup with:
- integrated camera, encoding, WiFi (or Ethernet if need be) - 1080p30 - single USB power source (lots of big battery choices) - station mode WiFi (not access point like GoPro) w/configurable IP - ideally RTSP server - less ideally RTMP client
Interestingly, iPhone 5 gets close using Wowza GoCoder app, but giving up my phone during a broadcast stinks...
Ubiquiti airCam also almost makes it, but no WiFi (though plays well w/UBNT WiFi products), and mainly the image quality isn't quite there.
Thanks!
Thanks: 5 times Was thanked: 2 time(s) in 2 post(s)
I can confirm the streaming size of the hero 3 is indeed 320 x 240 with a 2-4 second delay
How much you looking to spend on this? Teradek have some great products that will do the job.
 1 user thanked MrFreeze for this useful post.
MrFreeze wrote:I can confirm the streaming size of the hero 3 is indeed 320 x 240 with a 2-4 second delay
How much you looking to spend on this? Teradek have some great products that will do the job. Thanks Freeze - indeed Cubes are wonderful, but this is for a bridge with too much foot traffic and too little supervision. Hoping to cut down on piece & cable count as well. After writing the original query I actually plunked $ on an iPad Mini Retina. I do lose some frames at 1080p30, but what does get through looks very good. Biggest advantage is integration - one 11 Amp/Hour external battery does 9+ hours, and the MIMO Wi-Fi can do >70 mb over 300+ feet using a Ubiquiti 5MHz dish as the AP. Was about to build the cage that would give it a fighting chance of getting through each day unstolen, but then found out that city regulatory issues cut the course by 300 yards anyway, so no point - oh well... Thanks for the reply! David
