mrpap
#1 Posted : Saturday, January 30, 2021 10:07:54 PM(UTC)
mrpap
We are sending a feed via srt from OBS to Vmix and have noticed we get quite often audio glitches, is there a setting in Vmix we can play with to try and help?
Would lowering this help to say 41
richardgatarski
#2 Posted : Saturday, January 30, 2021 10:31:01 PM(UTC)
richardgatarski
Was thanked: 299 time(s) in 251 post(s)
"glitches" is a little bit vague, please describe.
You might wanna start by checking that you are sending 48 Khz from OBS. If the source is 44 Khz and receiver expect 48 Khz that typically creates glitches.
mrpap
#3 Posted : Saturday, January 30, 2021 10:58:20 PM(UTC)
mrpap
We are sending 44.1, can Vmix be lowered rather than putting obs to 48? Glitches it is like the music pauses, skips hard to explain but you can hear the "glitch"
richardgatarski
#4 Posted : Saturday, January 30, 2021 11:52:49 PM(UTC)
richardgatarski
yes, https://www.vmix.com/hel...tm?AdvancedSettings.html
But then you really have to make sure that all audio devices used by vMix are set to 44.1 Khz. In Windows that's done outside vMix in the Control panel/Sounds.
mrpap on 1/31/2021(UTC)
mrpap
#5 Posted : Sunday, January 31, 2021 2:54:22 AM(UTC)
mrpap
Appreciate that, can't see how i change it in Vmix though?
richardgatarski
#6 Posted : Sunday, January 31, 2021 3:03:19 AM(UTC)
richardgatarski
I do not understand what you do not understand.
Please re-read my post, think, and try.
