fatty
#1 Posted : Friday, January 29, 2021 10:15:39 AM(UTC)
fatty
I know that per the spec of vMix, intputs do not automatically play in anything other than the main mix.
However, I need this to happen. I've tried using a script unsuccesfully:
API.Function("Restart",Input:=0, Mix:=1)
API.Function("Play",Input:=0, Mix:=1)
API.Function("Cut",Input:=0, Mix:=1)
When I do this, the only line that actually executes is the last one.. The Restart and Play are ignored.
Any ideas for a workaround? I was thinking if maybe there's a way to find the reference to the input in the preview and then start it directly?
IE:
dim MyInput = Input.Find("Preview of Mix2)
API.Function("Play",MyInput)
Would something like that work?
fatty
#2 Posted : Friday, January 29, 2021 11:39:27 AM(UTC)
fatty
OK I've come up with this as a solution. It works but it seems REALLY clunky. Is there a better way?
'Get preview input
dim xml as string = API.XML()
x.loadxml(xml)
dim mix = x.SelectNodes("//mix")
dim previewInput = mix(0).ChildNodes(0).InnerXml
Api.Function("Restart", previewInput)
sleep(100) 'prevents screen flash
Api.Function("Play", previewInput)
#3 Posted : Friday, January 29, 2021 12:17:02 PM(UTC)
There is no way around it , Restart and play has to be instructed on the inputs themselves
fatty
#4 Posted : Friday, January 29, 2021 12:24:35 PM(UTC)
fatty
Wow. OK. I get why they turned that off by default, to prevent confusion. But there really should be a way to enable it if you know you want to do that. Making a work around turned 3 lines of code into 9. It works. Not pretty, but it's functional at least
#5 Posted : Friday, January 29, 2021 5:31:47 PM(UTC)
You already worked out a way ;-)
3 or 9 lines of code , how many times do you have to type them all? (copy/paste?)
