Does anyone know if there Is a scripting command that allows me to shut down (exit) vMix from within a script running on the local PC?
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
from within vMix ? google has ...... try this and link the script to a shortcut or streamdeck button (title the shortcut or mark the button with "suicide") ;-) Code:For Each prog As Process In Process.GetProcesses
If prog.ProcessName = "vMix64" Then
prog.Kill()
End If
Next
Thanks: 211 times Was thanked: 13 time(s) in 12 post(s)
I have done this where I used the HTTP Matrix tool from Eric Pratt and Windows Task Scheduler so I could set a specific time for this to happen after a video played out at a certain time and I wanted to shutdown vMix afterwards, so it can work fine depending on use case but I would not use a shortcut or button since as per doggy's reference to it as a potential "suicide" scenario
Automation for vMix is another option with everything in a single package
Thank you all for your help
