clincoln777
#1 Posted : Tuesday, January 26, 2021 3:22:22 AM(UTC)
clincoln777
Does anyone know if there Is a scripting command that allows me to shut down (exit) vMix from within a script running on the local PC?
#2 Posted : Tuesday, January 26, 2021 4:52:40 AM(UTC)
from within vMix ?
google has ......
try this and link the script to a shortcut or streamdeck button (title the shortcut or mark the button with "suicide") ;-)
Code:
For Each prog As Process In Process.GetProcesses
        If prog.ProcessName = "vMix64" Then
                prog.Kill()
        End If
Next
avsoundguy
#3 Posted : Tuesday, January 26, 2021 5:12:04 AM(UTC)
avsoundguy
I have done this where I used the HTTP Matrix tool from Eric Pratt and Windows Task Scheduler so I could set a specific time for this to happen after a video played out at a certain time and I wanted to shutdown vMix afterwards, so it can work fine depending on use case but I would not use a shortcut or button since as per doggy's reference to it as a potential "suicide" scenario
avsoundguy
#4 Posted : Tuesday, January 26, 2021 5:13:09 AM(UTC)
avsoundguy
Automation for vMix is another option with everything in a single package
clincoln777
#5 Posted : Thursday, May 9, 2024 1:46:38 AM(UTC)
clincoln777
Thank you all for your help
