diehard
#1 Posted : Friday, January 8, 2021 7:49:51 PM(UTC)
diehard
Lithuania
I've just stuck while trying to send sound to Buses A or B or whatever.
I have plenty of sound hardware installed inside my PC. And while it sends audio signal to real hardware - USB sound card or for instance Behringer UMC404HD, even NDI works!
However, it complete silence when I choose to send it to Virtual cables. In my case I use VB-Audio cables (CABLE Input, CABLE-A Input and CABLE-B Input). Just to mention - theese perfectly works in other apps.
Any ideas? What the heck is wrong?
andreypetr
#2 Posted : Saturday, January 9, 2021 8:18:12 AM(UTC)
andreypetr
Nice to see someone from Russia on forums.
I did a test just for you and it works fine.
1) Set audio out for a bus.
2) Be sure to enable audio, you will see a green audio meter.
3) Set your audio to a bus linked to your virtual cable.
4) It seems to work fine.
how to send audio to a virtual cable
thanks 1 user thanked andreypetr for this useful post.
diehard on 1/9/2021(UTC)
diehard
#3 Posted : Saturday, January 9, 2021 3:54:17 PM(UTC)
diehard
Lithuania
I know, HOW to configure it, 'cause it flawlessly works on another machine. However on the main streaming PC - does not. Thus it's clearly erroneous behaviour. Even have no ideas, where to dig for the root cause.
odoyle
#4 Posted : Sunday, January 24, 2021 7:08:45 PM(UTC)
odoyle
Italy
Hello @diehard have you solved the problem?
How is the Behringer UMC404HD is it fully compatible with Vmix and NDI ?
I want to patch 4 mics without a mixer is it useful ?
diehard
#5 Posted : Tuesday, January 26, 2021 12:38:26 AM(UTC)
diehard
Lithuania
Nope. Right now I am forced to use NDI Audio as a temporary solution.
This is good piece of equipment. It has two different modes: channels 1 + 2 and 3 + 4, (2 stereo channels). In the case of microphones, this is not the best config. But you can use 4 separate mono channels, which is the right choice for a microphone use case. I'm happy with this piece of hardware. Especially with WT Automixer plugin - it works like a charm.
AVolutionPro
#6 Posted : Wednesday, November 24, 2021 11:51:06 PM(UTC)
AVolutionPro
@diehard, did you ever find the root of this issue? I am having the same problem!
AngusFindlay
#7 Posted : Friday, December 3, 2021 1:29:01 AM(UTC)
AngusFindlay
I ran into a similar issue once, and the solution was to completely remove all of my VB Cables and reinstall them. Not a hint of trouble since.
