Joined: 2/27/2013(UTC) Posts: 312   Thanks: 8 times Was thanked: 78 time(s) in 43 post(s)
This may be a weird question. What determines if vMix is running at 29.97p or 59.94i or how can you tell which one vMix is outputting?
Joined: 10/13/2012(UTC) Posts: 1,162  Location: Melbourne Thanks: 220 times Was thanked: 200 time(s) in 181 post(s)
You set it in two places. 1st on the input when you setup a video capture; the 2nd in the Settinge/External Output tab. Have a look there and in the help. Should answer your question. Also look here: http://www.vmix.com.au/help12/LiveStreaming.html
But that doesn't tell me which on it is outputting. In every location is says 29.97 "OR" 59.94. So I am trying to find out if the signal that Is getting sent out my vMix fullscreen output is interlaced or progressive. How do I find this out?
