thecloudmediagroup
#1 Posted : 11 years ago
thecloudmediagroup
Was thanked: 78 time(s) in 43 post(s)
This may be a weird question. What determines if vMix is running at 29.97p or 59.94i or how can you tell which one vMix is outputting?
ask
#2 Posted : 11 years ago
ask
You set it in two places. 1st on the input when you setup a video capture; the 2nd in the Settinge/External Output tab. Have a look there and in the help. Should answer your question. Also look here: http://www.vmix.com.au/help12/LiveStreaming.html
thecloudmediagroup
#3 Posted : 11 years ago
thecloudmediagroup
But that doesn't tell me which on it is outputting. In every location is says 29.97 "OR" 59.94. So I am trying to find out if the signal that Is getting sent out my vMix fullscreen output is interlaced or progressive. How do I find this out?
