gefiltafish
#1 Posted : Saturday, January 23, 2021 12:31:55 AM(UTC)
gefiltafish
Hello, I'm new to scripting so I would need some help:
I have an API that sends me numerical data, and when that data hits X I would like that my vMix puts Overlay 1 on (Input 10 - databox, e.g.).
Is there a way to make a script (or some other way that I'm not seeing) that could help me?
Thanks in advanced,
Petar
Harpert
#2 Posted : Saturday, January 23, 2021 3:54:10 AM(UTC)
Harpert
Netherlands
Thanks in advanced,
Petar
There is an API which let's you send commands to Vmix on port 8088.
Search in the Manual for API.
you can write a script yourself that when your criteria are met, the command you need is sent to Vmix.
We have done this mulitiple times (using "C" dotnet) and that works perfectly
Harpert
#3 Posted : Saturday, January 23, 2021 4:00:54 AM(UTC)
Check the forum, quite a few examples for scripting in vMix !
gefiltafish
#4 Posted : Saturday, January 23, 2021 4:07:27 AM(UTC)
gefiltafish
Thanks in advanced,
Petar
Harpert
Hello, thanks for the help! Would you be so kind to send me an example please?
gefiltafish
#5 Posted : Saturday, January 23, 2021 4:08:32 AM(UTC)
gefiltafish
Searching, but I cannot find anything that is useful to this specific situation unfortunately. Any help (example/post) is appreciated!
Similar Topics
Data Source/Scripting Help (General Discussion)
by AndrewH 4/9/2026 2:13:15 PM(UTC)
Titling & scripting help/thoughts (General Discussion)
by MSFTGuruGuy 2/26/2023 3:21:22 AM(UTC)
Multiview Scripting Help (General Discussion)
by DaleH 6/22/2021 3:59:45 AM(UTC)
