Joined: 12/27/2012(UTC) Posts: 5,521  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Sure
There have been quite a few posts in this forum for similar requests with various solutions ( not for 40 mins but similar idea)
Joined: 10/10/2019(UTC) Posts: 63   Location: Düsseldorf Thanks: 3 times Was thanked: 14 time(s) in 8 post(s)
Originally Posted by: mrpap  I have two inputs, the first goes live to output for 40 mins, can it be automated that the next input auto switches after defined time in this case 40 mins, and then any subsequent inputs? Hi, that is pretty easy to do: 1. add two inputs 2. add a countdowntimer (GT Title preset is enough) 3. Go into the title editor from the timer and set it to 40 minutes 4. got to input 1 and under multiview pick any free layer and add the timecode, then unklick the checkmark before that timer (timer is now not visible when Input 1 is live) 5. Under input 1 settings goto trigger and add a trigger (On TransitionIn, StartCountdown, countdown input) 6. go into Countdown settings and add another trigger (OnCountdownCompleted, Fade, Input2) That's it. When you fade in Input1 the timer starts in background unvisible, when the timer is zero, Input 2 fades in. You can even see the timcode going down in the input thumbnail. So you know what time is left. Have fun
