rambouzi
#1 Posted : Thursday, January 14, 2021 12:38:09 AM(UTC)
rambouzi
Netherlands
I often use the ticker tape option to show the latest news headlines. That is working fine.
But i want to put a COLORED logo in between the headlines (see photo for example). Unfortunately that is still not possible. I was able create a logo in the selected font (replacing a unused character), but that one can only be the same color as the font.
I can also use a external app to create the ticker, but i don't want that.
So is it something that we can expect in the near future? Would me great. Or is there a 'tweak' or plugin to do this?
Thanks!!
#2 Posted : Thursday, January 14, 2021 1:01:33 AM(UTC)
oh it is possible ;-)
rambouzi
#3 Posted : Friday, January 15, 2021 10:41:33 PM(UTC)
rambouzi
Netherlands
Okay, great! But how?
Without using external sources. Just using the ticker option from vMix.
#4 Posted : Saturday, January 16, 2021 1:46:01 AM(UTC)
Those are custom made due to textblock content lenght restrictions, exact positioning of the elements and such but are GT titles
rambouzi
#5 Posted : Saturday, January 16, 2021 7:18:45 AM(UTC)
rambouzi
Netherlands
I see. That is not what i am looking for. But it looks great.
I want to use a RSS or XML data feed, to put the latest news in the ticker. The ticker shows headlines.
In between the headlines i want a colored logo of the station.
The length of the headlines is different every time.
In the data source settings of vMix there is a option 'format'. Here i can put a separator character(s).
If this option can be upgraded so graphics can be added than this problem is solved.
Would be great.
shawntempesta
#6 Posted : Sunday, January 17, 2021 7:21:57 AM(UTC)
shawntempesta
Was thanked: 9 time(s) in 7 post(s)
I get what you are asking for. Some ticker solutions call it a text delimiter. Essentially something to break up every story, be it something that says "Breaking News" or the logo of the show, etc. I've asked for this for a bit, others have as well. Not sure if it is coming, but it'd look great if they did!
rambouzi
#7 Posted : Tuesday, March 9, 2021 10:19:24 PM(UTC)
rambouzi
Netherlands
I did find a possible solution, but it is a bit of a overkill and rather expensive for just a Ticker.
CharacterWorks
https://www.chrworks.com/
(found it in this forum)
It can read xml files and is able to put animations, logo's, scores and al kind of other stuff in it. It is also using NDI.
I think I will try the demo version, but I'm not going to pay $2495,00 for it if I only use it for a ticker just occasionally.
So, if anyone has other good solutions, please let us know.
#8 Posted : Tuesday, March 9, 2021 11:08:58 PM(UTC)
Double ticker and some clever timing or scripting ;-)
or
https://hologfx.io/
