bain1320
#1 Posted : Thursday, January 7, 2021 8:46:23 PM(UTC)
bain1320
Russian Federation
Hello! I need to create a hotkey with which I will enable and disable triggers for one specific input.
Please tell me, I can't find a suitable function.
#2 Posted : Thursday, January 7, 2021 11:29:08 PM(UTC)
You're taking the problem upside down !
Use triggers for things that need to be triggered automatically all the time.
Otherwise use shortcuts to execute things at will.
By definition, there's no shortcut to enable or disable triggers
bain1320
#3 Posted : Friday, January 8, 2021 12:58:30 AM(UTC)
bain1320
Russian Federation
But I have such a need!
My triggers are configured for instant replays - they remove and return overlays.
During a sports game, it is necessary, but not during a break. If I do not manually turn off the triggers, the overlays will pop up, and this is not necessary during the break and after the game.
I would like to do this automatically using scripts or hotkeys.
#4 Posted : Friday, January 8, 2021 1:22:51 AM(UTC)
Well then figure out the logic and create a script ;-)
a trigger can call a script, a script can make a decision based on say a status or variable to do what your initial trigger does , have a shortcut ( hotkey) to change that state/variable and let the script again act based on that state ;-)
That's the beauty of vMix , you want something special it lets you do that one way or another
bain1320
#5 Posted : Friday, January 8, 2021 5:33:00 AM(UTC)
bain1320
Russian Federation
Perhaps you misunderstood me. What exactly will be the trigger - I know. I don’t know and don’t understand how, upon the occurrence of the event I need, to remove or return these checkmarks dfdfd.PNG (42kb) downloaded 2 time(s).
#6 Posted : Friday, January 8, 2021 6:46:49 AM(UTC)
We didn't
elvis55
#7 Posted : Friday, January 8, 2021 6:56:51 AM(UTC)
elvis55
Switzerland
Where is the problem? Mark everything, click in a square, all ticks are gone. You can leave the window in the system tray open as well as leave all triggers selected. Open the window quickly and click again in the square and the checkmarks are set again.
bain1320
#8 Posted : Saturday, January 9, 2021 2:08:38 AM(UTC)
bain1320
Russian Federation
Originally Posted by: elvis55 Go to Quoted Post
click again
Can this be done automatically?
Manually inconvenient, you can forget.
bain1320
#9 Posted : Saturday, January 9, 2021 2:14:02 AM(UTC)
bain1320
Russian Federation
I have a cell in the DataSource that contains the game time.
I want to create a script that will check what is contained in this cell and perform actions: if the content of this cell is 0:00 or 30:00 or 60:00, then turn off the checkboxes, otherwise turn on the checkboxes.
It is inconvenient by hand, I tried it in practice, you can easily forget about them.
#10 Posted : Saturday, January 9, 2021 3:39:37 AM(UTC)
It should have been clear by now that there is no way to activate/de-active a trigger by means of a shortcut or function
A script can perform all the actions of a trigger with the advantage of making a decision based on a criteria !
You mention based on the content of a cell , check out "scripting for dummies" post in this forum where you can find the solution
andreypetr
#11 Posted : Saturday, April 17, 2021 9:19:32 AM(UTC)
andreypetr
I actually double down on this idea. It will be convenient to enable/disable triggers from shortcuts. Today I made a somewhat complicated scene and having this possibility would've been great and actually saved time.
#12 Posted : Saturday, April 17, 2021 10:47:39 AM(UTC)
And how would one envision that , a shortcut to activate/deactivates them all or only specified ones etc , keeping track of them all or just a few ....
Triggers activate all the same functions that can be called with shortcuts or a script so let the trigger call a script and one can go as simple or complex as one wants , build in certain criteria to just ignore some or all function calls. The latest addition of dynamic inputs and values has even greatly expanded the options of creating complex logic based on a status or situation automatically.
mike16437
#13 Posted: : Sunday, April 18, 2021 5:51:20 AM(UTC)
mike16437
Is it too complicated within the constraints of your show to add a virtual input and just strip the triggers off, then use it as a separate source?
mike16437
#14 Posted : Sunday, April 18, 2021 6:05:34 AM(UTC)
mike16437
You could also create shortcut transition chains that would take a source "clean" for use during replays, then come out to a source "dirty". This would remove the need for your triggers on your source.
dtmmedia
#15 Posted : Monday, April 19, 2021 2:23:43 PM(UTC)
dtmmedia
This is what I was thinking as well, if you can't disable the trigger, just create a virtual input and remove the triggers, then assign that input to a separate hot-key.
wsteele
#16 Posted : Wednesday, April 6, 2022 4:41:24 AM(UTC)
wsteele
I'm very frustrated by people who think they know how people should do their workflows. The feature to temporarily enable and disable triggers is without a doubt useful. Why? Well I use audio triggers from a dozen mics to automatically switch between two PTZ cameras as well as automatically switch between PTZ presets. There are times during a live production where I want to control the cameras manually and since I still need the mic inputs the only option would be disabling triggers while I want manual control. Switching between different presets would interrupt the live stream. Even if a script can be used to replace the audio triggers, this seem like overkill to to do something rather simple that plenty of people are requesting.
