66 Pages«<5152535455>»
elgarf
#1041 Posted : Friday, November 27, 2020 9:05:48 AM(UTC)
elgarf
Russian Federation
Was thanked: 231 time(s) in 130 post(s)
@ivanm995, use SetImage script command or list with images fipe psths as source of items.
@jasminlord, one way is to make button, which start playing sound and add same hotkey for score "+1" and button "execute" events. But this will work only when score added through hotkey.
Papo
#1042 Posted : Wednesday, December 2, 2020 7:16:32 AM(UTC)
Papo
Peru
hello elgarf, look I don't know if it is implemented in utc, having a playlist option but that it is done through a timeline (NLE video editor type) being able to cut the movies into pieces and insert warnings into them or advertising, since you can change the mark in and mark out, this timeline will have as measurements the elapsed time seconds minutes and hours, it is only an idea maybe you could friend .. greetings
Spanish translated by google
Marlon
#1043 Posted : Saturday, December 12, 2020 6:54:01 AM(UTC)
Marlon
Germany
Hey elgarf,
is it possible to control utc with a stream deck?
elgarf
#1044 Posted : Saturday, December 12, 2020 11:38:47 PM(UTC)
elgarf
Russian Federation
@Papo, I think timeline is too complex feature for UTC.
@Marlon, not right now. I don't have streamdeck and can't test it =(
thanks 1 user thanked elgarf for this useful post.
leonardosfe219 on 12/14/2020(UTC)
leonardosfe219
#1045 Posted : Monday, December 14, 2020 12:11:39 PM(UTC)
leonardosfe219
Brazil
utc is still unable to input the fader velocity of the midi controller, I would like to control the volumes using the utc and an apc mini.
I know it is possible to do this in vmix, but I would like to control the volume using or utc, can someone help?
raf232
#1046 Posted : Thursday, December 17, 2020 7:49:02 PM(UTC)
raf232
Spain
I'm trying to take data from an Google Sheet with UTC "Google Sheet Data" but it doesn't work. The Google sheet works with Data Sources in vMix but not in UTC.
I have activated API in Google for Google Sheets.
I Put the Share link in "File path" on UTC but there are no Rows Loaded.
Any help?
Thank you very much.
elgarf
#1047 Posted : Thursday, December 17, 2020 10:19:55 PM(UTC)
elgarf
Russian Federation
@raf232, Google Sheets Data is incomplete, it's my mistake I put it into release folder =(
@leonardosfe219, at now hotkeys can't send additional parameters to buttons, so it's not possible to use faders. But I'll try to make it possible into next releases.
Right now I don't have enough time for UTC =(
raf232 on 12/17/2020(UTC)
raf232
#1048 Posted : Thursday, December 17, 2020 11:25:49 PM(UTC)
raf232
Spain
Ok!
Thanks also!
elgarf
#1049 Posted : Thursday, December 17, 2020 11:40:00 PM(UTC)
elgarf
Russian Federation
@leonardosfe219,
I made some changes in MIDI, so you can now access value from fader in script.
For example,
Code:
P * 100 / 127
Gives value from 0 to 100 for volume or something else.
leonardosfe219 on 12/19/2020(UTC)
Chircanu
#1050 Posted : Thursday, December 24, 2020 8:43:05 AM(UTC)
Chircanu
@leonardosfe219,
For example,
Code:
P * 100 / 127
Hello everyone, @elgarf, I know you do not have time, and this period is weaker in live broadcasts, but I would like to tell you that the last version of UTC(17.12) does not work execute-link. When you have a little time, I'd ask you to check it out, you're the father of UTC. All good wishes, guys!
elgarf
#1051 Posted : Thursday, December 24, 2020 6:04:15 PM(UTC)
elgarf
Russian Federation
@Chircanu, oops. Now should be fixed.
Chircanu on 12/25/2020(UTC)
elgarf
#1052 Posted : Tuesday, December 29, 2020 10:07:55 PM(UTC)
elgarf
Russian Federation
I decided to return "Table" mode in timer widget.
Why? Because it can help making animated timers =)
Wait for next update with new PlayList widget and Table & Split Text parameters for timer widget.
Sample of animated timer.
https://youtu.be/2G0A2ccvyps
Chircanu on 12/29/2020(UTC)
elgarf
#1053 Posted : Thursday, December 31, 2020 5:26:50 PM(UTC)
elgarf
Russian Federation
Last update in this year =)
Universal Title Controller (updated 24.12.2020)
thanks 2 users thanked elgarf for this useful post.
leonardosfe219 on 12/31/2020(UTC), Chircanu on 12/31/2020(UTC)
Chircanu
#1054 Posted : Thursday, December 31, 2020 9:45:42 PM(UTC)
Chircanu
Thank you so much for everything you've done for us. Happy birthday, 2021!
thanks 1 user thanked Chircanu for this useful post.
elgarf on 12/31/2020(UTC)
wolfmayr
#1055 Posted : Friday, January 1, 2021 2:25:28 AM(UTC)
wolfmayr
I want to know if there can be more than one utc client in the network to control one vmix?
Computer 1: UTC with timers
Computer 2: UTC to do lower thirds
Computer 3: Vmix gets commands from pc1 and 2
Thx
W.
wolfmayr
#1056 Posted : Friday, January 1, 2021 2:42:43 AM(UTC)
wolfmayr
dear elgarf,
i think there is a bug in UTC when using more then one timers.
f.e. icehockey
1st Timer: Default Time 00:20:00, Reverse checked - started timer (1st period match clock icehockey)
2nd Timer: Defalut Time 00:02:00, Reverse checkes - started timer when time one also running (f.e. penalty/powerplay icehockey)
then... powerplay ends (because of goal) - i click on "STOP" on 2nd timer - an one more click "RESET" - and now th bug happens - when resetting the second timer the first timer (the match clock) also gets paused...
can you please check this?
many thx
W bug_2timers.JPG (64kb) downloaded 11 time(s).
elgarf
#1057 Posted : Friday, January 1, 2021 10:25:46 PM(UTC)
elgarf
Russian Federation
@wolfmayr,
I fixed timer problem, I think.
You can use as many instances of UTC as you want, just don't use it for same things (like controlling same score from two computers, etc.)
wolfmayr on 1/2/2021(UTC)
marek69
#1058 Posted : Sunday, January 3, 2021 8:23:57 AM(UTC)
marek69
Poland
Hello, I have a problem. Instead of NDI Monitor, the NDI widget starts but only "properties" ?. NDI works perfectly normally on this computer. Why? Thank you in advance for your help
elgarf
#1059 Posted : Monday, January 4, 2021 2:28:13 AM(UTC)
elgarf
Russian Federation
@marek69, what if you create default external data widget and select dll from DataProviders folder?
Chircanu
#1060 Posted : Monday, January 4, 2021 3:00:38 AM(UTC)
Chircanu
Marek69, this is what happens after each update. There are two options: 1. delete the widget and create it again. 2. Put the new dll manually in the DataProviders/NDImonitor folder
Guest (12)
