Joined: 10/23/2015(UTC) Posts: 458   Thanks: 20 times Was thanked: 231 time(s) in 130 post(s)
@ivanm995, use SetImage script command or list with images fipe psths as source of items.
@jasminlord, one way is to make button, which start playing sound and add same hotkey for score "+1" and button "execute" events. But this will work only when score added through hotkey.
Joined: 6/16/2020(UTC) Posts: 77  Thanks: 8 times Was thanked: 2 time(s) in 2 post(s)
hello elgarf, look I don't know if it is implemented in utc, having a playlist option but that it is done through a timeline (NLE video editor type) being able to cut the movies into pieces and insert warnings into them or advertising, since you can change the mark in and mark out, this timeline will have as measurements the elapsed time seconds minutes and hours, it is only an idea maybe you could friend .. greetings Spanish translated by google
Hey elgarf,
is it possible to control utc with a stream deck?
@Papo, I think timeline is too complex feature for UTC.
@Marlon, not right now. I don't have streamdeck and can't test it =(
 1 user thanked elgarf for this useful post.
Joined: 9/25/2020(UTC) Posts: 3  Location: maringá-pr Thanks: 3 times
utc is still unable to input the fader velocity of the midi controller, I would like to control the volumes using the utc and an apc mini. I know it is possible to do this in vmix, but I would like to control the volume using or utc, can someone help?
Joined: 11/28/2018(UTC) Posts: 13  Location: Sant Cugat Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
Hello, I'm trying to take data from an Google Sheet with UTC "Google Sheet Data" but it doesn't work. The Google sheet works with Data Sources in vMix but not in UTC. I have activated API in Google for Google Sheets. I Put the Share link in "File path" on UTC but there are no Rows Loaded. Any help? Thank you very much.
@raf232, Google Sheets Data is incomplete, it's my mistake I put it into release folder =(
@leonardosfe219, at now hotkeys can't send additional parameters to buttons, so it's not possible to use faders. But I'll try to make it possible into next releases.
Right now I don't have enough time for UTC =(
Originally Posted by: elgarf  @raf232, Google Sheets Data is incomplete, it's my mistake I put it into release folder =(
Ok! Thanks also!
@leonardosfe219, I made some changes in MIDI, so you can now access value from fader in script. For example, Gives value from 0 to 100 for volume or something else.
Thanks: 75 times Was thanked: 7 time(s) in 7 post(s)
Originally Posted by: elgarf  @leonardosfe219, I made some changes in MIDI, so you can now access value from fader in script. For example, Gives value from 0 to 100 for volume or something else. Hello everyone, @elgarf, I know you do not have time, and this period is weaker in live broadcasts, but I would like to tell you that the last version of UTC(17.12) does not work execute-link. When you have a little time, I'd ask you to check it out, you're the father of UTC. All good wishes, guys!
@Chircanu, oops. Now should be fixed.
I decided to return "Table" mode in timer widget. Why? Because it can help making animated timers =) Wait for next update with new PlayList widget and Table & Split Text parameters for timer widget. Sample of animated timer. https://youtu.be/2G0A2ccvyps
 2 users thanked elgarf for this useful post.
Thank you so much for everything you've done for us. Happy birthday, 2021!
 1 user thanked Chircanu for this useful post.
I want to know if there can be more than one utc client in the network to control one vmix? Computer 1: UTC with timers Computer 2: UTC to do lower thirds Computer 3: Vmix gets commands from pc1 and 2 Thx W.
dear elgarf, i think there is a bug in UTC when using more then one timers. f.e. icehockey 1st Timer: Default Time 00:20:00, Reverse checked - started timer (1st period match clock icehockey) 2nd Timer: Defalut Time 00:02:00, Reverse checkes - started timer when time one also running (f.e. penalty/powerplay icehockey) then... powerplay ends (because of goal) - i click on "STOP" on 2nd timer - an one more click "RESET" - and now th bug happens - when resetting the second timer the first timer (the match clock) also gets paused... can you please check this? many thx W  bug_2timers.JPG (64kb) downloaded 11 time(s).
@wolfmayr, I fixed timer problem, I think.
You can use as many instances of UTC as you want, just don't use it for same things (like controlling same score from two computers, etc.)
Joined: 11/5/2018(UTC) Posts: 15  Location: Bielsko-Biała
Hello, I have a problem. Instead of NDI Monitor, the NDI widget starts but only "properties" ?. NDI works perfectly normally on this computer. Why? Thank you in advance for your help
@marek69, what if you create default external data widget and select dll from DataProviders folder?
Originally Posted by: marek69  Hello, I have a problem. Instead of NDI Monitor, the NDI widget starts but only "properties" ?. NDI works perfectly normally on this computer. Why? Thank you in advance for your help Marek69, this is what happens after each update. There are two options: 1. delete the widget and create it again. 2. Put the new dll manually in the DataProviders/NDImonitor folder
