sparkyjcm
#1 Posted: : Monday, December 28, 2020 11:18:48 AM(UTC)
sparkyjcm
Hello, all
Our livestream sounds great but people have complained that they have to turn their tv or device all the way up in order to hear. Vmix shows levels in yellow, some red here and there but not often. If I push anything up a little in vmix or the soundboard or the audio interface, it distorts the sound. We run from the soundboard to an audient id14 in vmix. I’ve tried backing off the levels of the audio in vmix (which have by default always been at the max) while pushing up the soundboard output to the interface. I’ve also tried raising the main level (when you click the gear on the audio input) but starts distorting. This setting has always been at zero. Seems I’m right at a threshold but need it to where users don’t have to turn their device all the way up. Anything I’m missing? Thanks.
#2 Posted : Monday, December 28, 2020 6:48:03 PM(UTC)
Give is a link so that we can check
It's not rare to see people complaining when the issue is on their side
SportsNetUSA.net
#3 Posted : Tuesday, December 29, 2020 3:51:06 AM(UTC)
SportsNetUSA.net
How are you monitoring the audio your vMix stream, from the soundboard, audio interface or vMix computer?
Do you have your vMix computer as an input to your soundboard?
Is your iD14 connected via USB to the vMix computer or with an analog cable?
How is the soundboard connected to the iD14? Analog? USB?
Phantom power turned off on Audient iD14?
sparkyjcm
#4 Posted : Wednesday, December 30, 2020 5:54:48 AM(UTC)
sparkyjcm
Seems when the video gets up on YouTube etc the day after the livestream it is better. I’m guessing they process it to have better audio levels?
I have noticed the same though and have to turn up the device or tv all the way up. I don’t have a great way to monitor during livestream other than YouTube or fb through my phone to my Bluetooth hearing aids.
The id14 is connected via usb. We run out of the soundboard through one of its outputs. I need to double check to make sure phantom power is off.
I plan on trying the waves ultra maximizer to see if it’ll help. I also have to adjust volumes quite a bit while the stream is going so maybe this will help raise my overall volume and make it consistent. Hopefully?
SportsNetUSA.net
#5 Posted : Wednesday, December 30, 2020 9:39:23 AM(UTC)
SportsNetUSA.net
What is brand/model of your soundboard?
Correct me please, your sound chain is:
- Soundboard Output to Audient iD14 using analog cables
- Audient iD14 to vMix computer using USB interface
Are you running the Audient software on the vMix computer?
What does the audio sound like when you monitor with headphones out of the iD14?
If you have the time, you should find out what the actual problem is. More processing is usually not the most desirable way to fix audio problems when the source audio is good.
sparkyjcm
#6 Posted : Wednesday, December 30, 2020 12:15:18 PM(UTC)
sparkyjcm
What is brand/model of your soundboard? Not sure. I’ll check. It’s pretty old school.
Correct.
Are you running the Audient software on the vMix computer? Yes I am.
What does the audio sound like when you monitor with headphones out of the iD14? Sounds great with headphones out of the audient but I do have to turn the headphone level all the way up.
I’ve confirmed phantom power is off.
Thanks for the help.
Babbit
#7 Posted : Wednesday, December 30, 2020 12:57:11 PM(UTC)
Babbit
Was thanked: 26 time(s) in 20 post(s)
Not likely, but make sure you're not in a line level to mic level situation. Looks like your Audient expects 1/4" connectors for line level.
SportsNetUSA.net
#8 Posted : Wednesday, December 30, 2020 2:43:05 PM(UTC)
SportsNetUSA.net
Babbit,
I think you are on to the same thing I was thinking with the line/mic levels. I used to have announcers that would always switch the mixer outputs to the wrong level. Once I had to drive 70+ miles just to flip a switch in the back of a mixer in the wrong mode.
Stuart McCafferty
#9 Posted : Wednesday, December 30, 2020 10:55:19 PM(UTC)
Stuart McCafferty
What are you streaming it too, we found that we had a similar issue streaming our weekly football (soccer) game when using vimeo, we found dropping the bit rate helped our viewers.
sparkyjcm
#10 Posted : Thursday, December 31, 2020 6:02:23 AM(UTC)
sparkyjcm
Not sure I understand the line level to mic level reference.
I do use a 1/4 cable from the soundboard output to the audient.
sparkyjcm
#11 Posted : Thursday, December 31, 2020 10:34:01 AM(UTC)
sparkyjcm
I think you all are right. In livestream tonight in the audient software, I see my input is hot but shows as mic1.
Edit: never mind. Looks like there is no way to differentiate between line and mic on the audient. Will show just either mic, optical, or DAW. But it still comes in hot here and I can’t seem to adjust it anywhere.
Babbit
#12 Posted : Thursday, December 31, 2020 2:07:32 PM(UTC)
Babbit
I've dealt with a few old USB interfaces where the audio comes in hot no matter what. Ultimately I wound up using a -40 dB pad, which is indicative of line level audio into a mic level input. Previous engineers tried -20 dB, which covers pro line level to consumer, and it was still distorted unless set to some ungodly quiet level. Quiet and field IFB don't exactly mix.
You can get inline XLR pads for relatively cheap, some with selectable pad values. Or if you like soldering and have resistors handy, make your own.
