Rubber Man
#1 Posted : Saturday, December 26, 2020 7:09:14 PM(UTC)
Rubber Man
If I have VLC outputting NDI on one PC can I use this as a NDI Input source for vMix on two or three other PC's on the LAN at the same time?
Or will it degrade the picture quality or cause vMix NDI Input issues with multiple PC access?
Thx
#2 Posted : Saturday, December 26, 2020 7:43:01 PM(UTC)
yes
elvis55
#3 Posted : Saturday, December 26, 2020 8:20:22 PM(UTC)
elvis55
Switzerland
NDI Network Bandwidth
NDI operates most efficiently in a dedicated network with high bandwidth and high availability. This is in contrast to unmanaged environments such as the public Internet or networks where video rides along with data without priority.
While a single stream of HD video can easily be delivered on a Fast Ethernet (100 Mbps) network, Gigabit (1000 Mbps) networks are essential in production workflows. A typical NDI stream consisting of 1080i HD video yields a data rate up to 100 Mbps per stream. This extremely efficient stream is designed to have very low latency and allows multiple streams to be stacked together on a single Gigabit network.
Less bandwidth is needed with NDI / HX
NDI® | HX also requires less bandwidth than, for example, the RTSP protocol. The bandwidth actually required depends on the resolution of the live stream used. In general, however, the bandwidth is around 10 Mbit / s.
Try it out once with SRT in VLC.
VLC media player and SRT
In VLC - network stream / network e.g. srt: //192.168.1.20: 10000
In vMix - Type: Listener - Port: 10000
example:
(192.168.1.20 network address of vMix PC)
thanks 1 user thanked elvis55 for this useful post.
Rubber Man on 12/27/2020(UTC)
mavik
#4 Posted : Wednesday, January 6, 2021 7:30:01 AM(UTC)
mavik
Was thanked: 197 time(s) in 177 post(s)
I have done a video on NDI bandwidth. This might help to understand it better.
