Feature Requests
add a functional “aspect“ ?
Rank:: Member
in vmix,If there's a lot of material that's 4:3,It will be very troublesome to change the ratio to 16:9,It needs one change after another, which is very troublesome and time-consuming. if Add the function "aspect"under the "input"category,You can do this in batches by writing a script that calls the function,The efficiency will be greatly improved.
Rank:: Member
Can vmix add functions to scale the X and Y axes,zoomx and zoomy?thank you
Joined: 3/20/2014(UTC) Posts: 2,719   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
It is not very difficult to zoom in a 4/3 input so that left and right borders disappear.
Rank:: Member
now ,in “input“ have a function “setzoom” to chang zoom rate in Proportional.If you want to change X,Y alone, you can't do it.
Quote:If you want to change X,Y alone, you can't do it. It would result in a distorted image, so no, vMix does not obviously allow to do this !
Rank:: Member
“zoomx,zoomy “ funtion,
add a funcution what judge the material's width and High
three function cooperate,
Rank:: Member
Originally Posted by: DWAM  It is not very difficult to zoom in a 4/3 input so that left and right borders disappear. must manualy right click to set the x,y slide bar,but i want to realise this goal with shortcut or scripting ,moreover chang for all materials in batches.of course,judgment statement
Rank:: Member
one key restart to beginner for all one key loop one key play one by one for all one key audio on/off for all
above all i have realised with scripting
now,i wish to aspect(now no) or zoomx or zoomy,but no functions ,so i hope adding function “zoomx“, “zoomy“ or “aspect“,thank you!
Rank:: Member
i don't know why you understand what i have expressed
Rank:: Member
i don't know why you don't understand what i have expressed
Rank:: Member
Feature Requests
