Feature Requests
add a functional “aspect“ ?
in vmix,If there's a lot of material that's 4:3,It will be very troublesome to change the ratio to 16:9,It needs one change after another, which is very troublesome and time-consuming. if Add the function "aspect"under the "input"category,You can do this in batches by writing a script that calls the function,The efficiency will be greatly improved.
Can vmix add functions to scale the X and Y axes,zoomx and zoomy?thank you
Joined: 3/20/2014(UTC) Posts: 2,719   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
It is not very difficult to zoom in a 4/3 input so that left and right borders disappear.
now ,in “input“ have a function “setzoom” to chang zoom rate in Proportional.If you want to change X,Y alone, you can't do it.
Quote:If you want to change X,Y alone, you can't do it. It would result in a distorted image, so no, vMix does not obviously allow to do this !
“zoomx,zoomy “ funtion,
add a funcution what judge the material's width and High
three function cooperate,
Originally Posted by: DWAM  It is not very difficult to zoom in a 4/3 input so that left and right borders disappear. must manualy right click to set the x,y slide bar,but i want to realise this goal with shortcut or scripting ,moreover chang for all materials in batches.of course,judgment statement
one key restart to beginner for all one key loop one key play one by one for all one key audio on/off for all
above all i have realised with scripting
now,i wish to aspect(now no) or zoomx or zoomy,but no functions ,so i hope adding function “zoomx“, “zoomy“ or “aspect“,thank you!
i don't know why you understand what i have expressed
i don't know why you don't understand what i have expressed
Feature Requests
