Feature Requests
Custom thumbnail for inputs
Rank:: Advanced Member
Joined: 8/24/2019(UTC) Posts: 48  Location: Montreal Thanks: 7 times Was thanked: 1 time(s) in 1 post(s)
Originally Posted by: DWAM  Quote:All of my videos have fades, so 1st frame is useless. Play your videos until a meaningful part and pause them Use the "restart with transition" feature That works somewhat, but is just a lame workaround. This is an easy fix and I agree it should have been done already.
Joined: 4/23/2017(UTC) Posts: 1,484  Location: Germany Thanks: 3 times Was thanked: 197 time(s) in 177 post(s)
Joined: 12/19/2020(UTC) Posts: 2  Location: greaterpoland
Yeach. so many years of developing very good software with this one big minus about thumbnails.... with 6 is okay but what if i have 30 similars thumbnails.... omg  Zrzut ekranu 2020-12-19 111035.jpg (265kb) downloaded 4 time(s).
Joined: 12/27/2012(UTC) Posts: 5,527  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: Bomber93  Yeach. so many years of developing very good software with this one big minus about thumbnails.... with 6 is okay but what if i have 30 similars thumbnails.... omg
Give them more simplified names, should have too ;-)  thmbnl.JPG (78kb) downloaded 10 time(s).
yeach... do you have time to reading little titles when live is on air ? Im not have time for this... its only one feature what is missing in vmix to make vmix full prosfesional software
Originally Posted by: Bomber93  yeach... do you have time to reading little titles when live is on air ? Im not have time for this... its only one feature what is missing in vmix to make vmix full prosfesional software merely pointing out that unless one has multiple custom thumbnails, that based on part of the footage that it also can be confusing as are long names instead of shorter ones . Luckely we have shortcut options etc available
Joined: 12/21/2020(UTC) Posts: 12  Location: Indiana Thanks: 2 times Was thanked: 4 time(s) in 2 post(s)
+1 for this feature, it would be very useful
I have already given this solution on the forum long ago but here it is again:
- create your thumbnail file one way or another. vMix provides a command to produce thumbnails on the fly and a command to add any file to the project. A single shortcut can do it all at once. - add this thumbnail as layer 1 to your input - now your input shows whatever you decided Done!
If you want to push it a little further, just add a trigger for this input to "hide" layer1 on transition in and to show it again on transition out. Now you see real-time preview window in the input bar when your video is playing and your thumbnail when the video is paused.
 2 users thanked DWAM for this useful post.
Thanks: 185 times Was thanked: 20 time(s) in 17 post(s)
Joined: 9/30/2020(UTC) Posts: 4  Location: Isle of Man
Rank:: Newbie
Joined: 5/20/2017(UTC) Posts: 62   Location: Philippines Thanks: 170 times Was thanked: 3 time(s) in 2 post(s)
Joined: 8/16/2019(UTC) Posts: 357  Thanks: 80 times Was thanked: 24 time(s) in 19 post(s)
+1 Good idea. Just have to wait another 3 years for it to be implemented lol
Joined: 5/19/2017(UTC) Posts: 103   Location: The Netherlands Thanks: 15 times Was thanked: 36 time(s) in 24 post(s)
Joined: 1/17/2023(UTC) Posts: 14  Location: Denver Was thanked: 1 time(s) in 1 post(s)
+1 for this feature I am even OK with the thumbnail being some way lower resolution just to save system/GPU memory in the UI. Originally Posted by: DWAM  I have already given this solution on the forum long ago but here it is again:
If you want to push it a little further, just add a trigger for this input to "hide" layer1 on transition in and to show it again on transition out. Now you see real-time preview window in the input bar when your video is playing and your thumbnail when the video is paused. Not a bad work-around but doesn't having another input added now consume more video memory? I already have so many inputs than I can easily manage (even with categories) I don't know if I want thumbnail cards tossed in there.
Joined: 2/14/2024(UTC) Posts: 9  Location: Liverpool Thanks: 1 times
It would be great to be able to choose a frame from the input as the thumbnail instead of it defaulting to the first frame. As mentioned, adding 20 images to use as thumbnails for 20 videos is a bit much for a workaround.
Originally Posted by: samsp  It would be great to be able to choose a frame from the input as the thumbnail instead of it defaulting to the first frame. As mentioned, adding 20 images to use as thumbnails for 20 videos is a bit much for a workaround. If you create a SD shortcut one can show a thumbnail of it (choose thumbnaisl for display option)
This would definitely be beneficial. I am currently looking for a a solution to this. Any updates on this request from VMIX
Joined: 1/9/2019(UTC) Posts: 86   Location: Stockholm Thanks: 25 times Was thanked: 5 time(s) in 4 post(s)
+1
Very useful - even if it's possible to achieve this with suggested workarounds.
Feature Requests
