dror
#1 Posted : Saturday, October 17, 2020 7:42:51 AM(UTC)
dror
Israel
Hi All Can some on help me with the Web api command to set the Start Time Of the countdown?
i can set the Duration With This Command
Function=SetCountdown&SelectedIndex=2&Value=00:59:00&Input=1
But I couldent Find the Start Time command
best regards
#2 Posted : Saturday, October 17, 2020 5:41:12 PM(UTC)
These are your options
dror
#3 Posted : Saturday, October 17, 2020 6:17:50 PM(UTC)
dror
Israel
Thank you For The replay
I have tested all the option and didn't managed to make it work...
only to set the duration
#4 Posted : Saturday, October 17, 2020 6:37:10 PM(UTC)
Maybe explain better what you like to achieve as there is NO StartTime in a countdown
dror
#5 Posted : Saturday, October 17, 2020 6:54:36 PM(UTC)
dror
Israel
I have this title with the Countdown
I would like to control the star time
and set it to 00:00:00
#6 Posted : Saturday, October 17, 2020 7:19:49 PM(UTC)
I see, my mistake
Guess not then (by shortcut or web api)
dror
#7 Posted : Saturday, October 17, 2020 7:31:16 PM(UTC)
dror
Israel
thank you very much for the help
BSSTL
#8 Posted : Saturday, December 19, 2020 6:28:42 PM(UTC)
BSSTL
I am having trouble getting my clock to set duration.
Function=SetCountdown&Value=00:00:10&Input=CLOCK
#9 Posted: : Saturday, December 19, 2020 6:59:13 PM(UTC)
More details needed.
Where/how are you using the function, is the input just named clock, is there a clock already specified in the title, what textblock is it supposed to be in ? ..............
BSSTL
#10 Posted : Saturday, December 19, 2020 7:03:15 PM(UTC)
BSSTL
Where/how are you using the function, is the input just named clock, is ther a clock already specified in the title ? ..............
Input 12 is named CLOCK. I am trying to make a script for several different durations. 3:00, 2:30, :20,
I can get the clock to start by using function=StartCountdown&Input=CLOCK
But cant get a script to work for changing duration
#11 Posted : Saturday, December 19, 2020 7:08:45 PM(UTC)
you need to make sure the input (textblock) is specified (when creating a shortcut , check what all is needed for comparison)
you mention script for different durations , just wondering how you are making a decision in the script
BSSTL
#12 Posted : Saturday, December 19, 2020 7:15:06 PM(UTC)
BSSTL
I am not understanding.
My goal is to have have 3 shortcut buttons on my stream deck that do the same function. The only difference will be be the duration of the clock. Basically the 3 buttons will put another input online, and play either a 3:00, 2:30, or :20 clock depending on which shortcut button i push on my stream deck.
I am very new to scripting and coding. Can you assist me with the clock duration line of command?
I need it to set the duration of the countdown clock (input 12) to 3:00.
#13 Posted : Saturday, December 19, 2020 7:47:17 PM(UTC)
Makes 2 of us
Shortcuts and vMix scripting are 2 different things !
Shotcuts can contain multiple functions at the same time (as can scripts)
so for example: one shortcut can set the clock dor 3:00, activate the input wanted and oncountdowncompleted deactivate that input or whatever needs to be done after time is completed
Regarding the setting of the countdown clock i mentioned before to check the items that are needed when you create a shortcut , more specifically your function does NOT contain the specific title line (Textblock) where your countdown is defined . if you want the function to be used in a script the same items and data are needed
#14 Posted : Saturday, December 19, 2020 7:58:55 PM(UTC)
Function=SetCountdown&Input=CLOCK&Title=Headline.Text&Value=00:03:00
BSSTL
#15 Posted : Saturday, December 19, 2020 8:01:13 PM(UTC)
BSSTL
what worked for me:
FUnction=SetCountdown&Input=CLOCK&Value=00:00:10&SelectedName=Timer.Text
#16 Posted : Saturday, December 19, 2020 8:16:55 PM(UTC)
what worked for me:
SelectedName or selectedIndex is def needed when using the API.function format as there "Title" doesn't work ;-)
API.Function("SetCountdown",Input:="CLOCK",SelectedName:="Headline.Text",Value:="00:03:00")
