Hi All Can some on help me with the Web api command to set the Start Time Of the countdown? i can set the Duration With This Command Function=SetCountdown&SelectedIndex=2&Value=00:59:00&Input=1 But I couldent Find the Start Time command
best regards
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
These are your options  countdown.JPG (37kb) downloaded 10 time(s).
Thank you For The replay I have tested all the option and didn't managed to make it work... only to set the duration
Maybe explain better what you like to achieve as there is NO StartTime in a countdown  countdown2.JPG (44kb) downloaded 11 time(s).
 clock.png (22kb) downloaded 10 time(s).I have this title with the Countdown I would like to control the star time and set it to 00:00:00  clock.png (8kb) downloaded 11 time(s).
I see, my mistake
Guess not then (by shortcut or web api)
thank you very much for the help
I am having trouble getting my clock to set duration.
Function=SetCountdown&Value=00:00:10&Input=CLOCK
Originally Posted by: BSSTL  I am having trouble getting my clock to set duration.
Function=SetCountdown&Value=00:00:10&Input=CLOCK More details needed. Where/how are you using the function, is the input just named clock, is there a clock already specified in the title, what textblock is it supposed to be in ? ..............
Originally Posted by: doggy  Originally Posted by: BSSTL  I am having trouble getting my clock to set duration.
Function=SetCountdown&Value=00:00:10&Input=CLOCK More details needed. Where/how are you using the function, is the input just named clock, is ther a clock already specified in the title ? .............. Input 12 is named CLOCK. I am trying to make a script for several different durations. 3:00, 2:30, :20, I can get the clock to start by using function=StartCountdown&Input=CLOCK But cant get a script to work for changing duration
Originally Posted by: BSSTL  Input 12 is named CLOCK. I am trying to make a script for several different durations. 3:00, 2:30, :20,
you need to make sure the input (textblock) is specified (when creating a shortcut , check what all is needed for comparison) you mention script for different durations , just wondering how you are making a decision in the script
Originally Posted by: doggy  Originally Posted by: BSSTL  Input 12 is named CLOCK. I am trying to make a script for several different durations. 3:00, 2:30, :20,
you need to make sure the input (textblock) is specified (when creating a shortcut , check what all is needed for comparison) you mention script for different durations , just wondering how you are making a decision in the script I am not understanding. My goal is to have have 3 shortcut buttons on my stream deck that do the same function. The only difference will be be the duration of the clock. Basically the 3 buttons will put another input online, and play either a 3:00, 2:30, or :20 clock depending on which shortcut button i push on my stream deck. I am very new to scripting and coding. Can you assist me with the clock duration line of command? I need it to set the duration of the countdown clock (input 12) to 3:00.
Makes 2 of us Shortcuts and vMix scripting are 2 different things ! Shotcuts can contain multiple functions at the same time (as can scripts) so for example: one shortcut can set the clock dor 3:00, activate the input wanted and oncountdowncompleted deactivate that input or whatever needs to be done after time is completed Regarding the setting of the countdown clock i mentioned before to check the items that are needed when you create a shortcut , more specifically your function does NOT contain the specific title line (Textblock) where your countdown is defined . if you want the function to be used in a script the same items and data are needed  countdown.JPG (44kb) downloaded 10 time(s).
Function=SetCountdown&Input=CLOCK&Title=Headline.Text&Value=00:03:00
Originally Posted by: doggy  Function=SetCountdown&Input=CLOCK&Title=Headline.Text&Value=00:03:00 what worked for me: FUnction=SetCountdown&Input=CLOCK&Value=00:00:10&SelectedName=Timer.Text
Originally Posted by: BSSTL  Originally Posted by: doggy  Function=SetCountdown&Input=CLOCK&Title=Headline.Text&Value=00:03:00 what worked for me: FUnction=SetCountdown&Input=CLOCK&Value=00:00:10&SelectedName=Timer.Text SelectedName or selectedIndex is def needed when using the API.function format as there "Title" doesn't work ;-) API.Function("SetCountdown",Input:="CLOCK",SelectedName:="Headline.Text",Value:="00:03:00")
