MIDI issues on toggle functions
I have just got a lovely midi controller the Novation LaunchPad Mini (Mk3) which I would love to integrate with my vMix as I am almost always the sole operator and "performer".
It has been going well, apart from this issue - where I need to send just a single "note" to toggle a function ie "Audio" which is an On/Off function. It seems to immediately send another "note" which turns it off again! I don't want to have to keep my finger on the button all the time!
This is also noticeable when triggering a transition from Preview to Live ie CrossFade or Merge. It stutters because multiple CrossFade/Merge signals are being sent.
Is there a way to gt vMix only to accept a single "note" at a time? Or is there a fix at the Midi end?
If anyone has overcome this with MIDI, I'd be grateful to hear from them.
Thank you.
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
set your shorcut on the off state
Originally Posted by: DWAM  set your shorcut on the off state Sorry, I don't quite understand. I didn't want two buttons: one for on and one for off because a single button that does on/off is obviously better. A keypress shortcut mamanges that. Can you describe a little more what you mean please?
a midi button has 2 states: - one is when you press the button > ON - one when you release the button > OFF
From your description it seems that your command is set for both > ON triggers the command and OFF triggers the command again
So make sure to set your shortcut on either ON or OFF but not both.
