Fr.Simon
#1 Posted : Monday, December 14, 2020 8:25:58 PM(UTC)
Fr.Simon
I have just got a lovely midi controller the Novation LaunchPad Mini (Mk3) which I would love to integrate with my vMix as I am almost always the sole operator and "performer".
It has been going well, apart from this issue - where I need to send just a single "note" to toggle a function ie "Audio" which is an On/Off function. It seems to immediately send another "note" which turns it off again! I don't want to have to keep my finger on the button all the time!
This is also noticeable when triggering a transition from Preview to Live ie CrossFade or Merge. It stutters because multiple CrossFade/Merge signals are being sent.
Is there a way to gt vMix only to accept a single "note" at a time? Or is there a fix at the Midi end?
If anyone has overcome this with MIDI, I'd be grateful to hear from them.
Thank you.
#2 Posted : Monday, December 14, 2020 8:43:13 PM(UTC)
set your shorcut on the off state
Fr.Simon
#3 Posted : Monday, December 14, 2020 9:26:03 PM(UTC)
Fr.Simon
Sorry, I don't quite understand.
I didn't want two buttons: one for on and one for off because a single button that does on/off is obviously better. A keypress shortcut mamanges that. Can you describe a little more what you mean please?
#4 Posted : Monday, December 14, 2020 9:32:50 PM(UTC)
a midi button has 2 states:
- one is when you press the button > ON
- one when you release the button > OFF
From your description it seems that your command is set for both > ON triggers the command and OFF triggers the command again
So make sure to set your shortcut on either ON or OFF but not both.
Fr.Simon
#5 Posted : Monday, December 14, 2020 9:38:18 PM(UTC)
Fr.Simon
Gottit - Thank you!
