jozee
#1 Posted : Monday, December 14, 2020 5:46:47 PM(UTC)
jozee
I know about the post that says to downgrade the drivers however 30XX does not have an older driver.
vmix performance has been degraded scientifically because of that issue and vmix people should fix it ASAP.
the "desktop windows manager" usage is also because vmix, if i close vmix it goes to 0%-1%.
#2 Posted : Monday, December 14, 2020 6:10:27 PM(UTC)
It's not vMix fault ! And vMix responsability IS NOT to solve Nvidia issues. Complain to Nvidia !
#3 Posted : Monday, December 14, 2020 7:13:29 PM(UTC)
Was thanked: 4718 time(s) in 1616 post(s)
Please be patient, we have submitted a bug report to NVIDIA and they are taking a look at it.
jozee
#4 Posted : Monday, December 14, 2020 7:24:37 PM(UTC)
jozee
it's not affecting any other software AFAIK, i'm using premiere, after effects, resolve, 3dsmax, unreal engine, aximmetry so...
#5 Posted : Monday, December 14, 2020 8:00:27 PM(UTC)
SO what ? None of these are live production softwares and use the GPU the same way vMix does...
I believe there are 3 options :
- Nvidia newest GTX/RTX drivers have a "problem" to work correctly for what vMix does, the way it used to work. If they had announced they'd changed something in regards to live video support, I believe Martin would have taken care of it. The fact that apparently they didn't announce anything about it tends to prove the issue is on their side. Hopefully they will correct the drivers soon.
- Nvidia newest GTX/RTX drivers are supposed to work the way they now do. In this case, not only the 3xxx series are impacted but also all previous generations which used to work fine with vMix. This proves they changed something that breaks vMix code. I'm sure Martin is investigating and will soon report his findings. Either he can solve the problem or not. But I believe this is not a simple and easy solution to deal with as there seems to be an important rewrite to do for drivers greater than 452.06 and nothing proves that this rewrite will still work fine for previous drivers. This potentially underlies that vMix would need to run different code in regards to which drivers are used.
- We have to consider that
> RTX 3xxx series is incompatible with vMix
> drivers greater than 452.06 are incompatible with vMix for all GTX/RTX series
I think it's too soon to tell but I think Martin would not have asked us NOT to use drivers greater than 452.06 if the solution was in his hands. He would have done the job like he always did.
